查看: 2653|回复: 0
[其他] Wallys/DB wifi router/IPQ6010/2.4G/5G QCN9074 QCN9024 openwrt USB2.0
签到总奖励:18金币
发表于 2023-2-14 13:27:29 | 显示全部楼层 |阅读模式
QCN9074 WiFi 6E Card OpenWRT, IPQ6010,802.11ax,
2x2 2.4G&5G 2.5Gbps Ethernet Port Support OpenWRT SupportUECTEL RM500Q-GL.
The wifi6 routerboard from Wallys is a popular product that many customers want.
It supports the QCN9074 series of M.2 card, while the remover card is supported.
It can meet the needs of more customers, but if some parameters need to be adjusted, wallys can meet them.
Qualcomm-Atheros IPQ6010
Quad-core ARM 64bit A53 @1.8GHz Processor
1GB DDRL3L System Memory
32MB NOR Flash, 256MB NAND Flash
Support: QUECTEL RM500Q-GL
Support: QCN9074 WiFi 6E Card
    Absolute Maximum Rating
    Parameter
    Rating
    Unit
    Supply Voltage
    24V~48
    V
    Operating Temperature Range
    -40 to +70
    ºC
    Storage Temperature Range
    -45 to +105
    ºC
    Operating Humidity Range
    5 to +95 (non-condensing)
    Hardware Specifications
    Symbol
    Parameter
    CPU
    CPU Frequency
    Quad-core ARM 64 bit A53 @1.8 GHz processor
    System Memory
    1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design
    Ethernet Port
    1 x 1Gbps Ethernet Ports & POE3 x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port
    NGFF Slot
    M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0
    SD Card Slot
    1x SD Card Slot
    USB /header
    1x USB 2.0 Port
    POE
    24V~48V passive POE/Active POE(Suport 802.3bt)
    DC Jack
    24V power supply
    LED header
    FFC/FPC Connector
    Serial Port
    1x Serial Port 4 Pin Connector
    Wireless
    On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax, max 23dBm per chain
    On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain
    4 x MMCX Connectors
    Bluetoothoptional
    Nor Flash
    8-32MB(normally is 8MB)
    Nand Flash
    256MB
    DDR
    1GB
    Dimension
    185mm x 116mm
      Boot Config Switch
      Boot_Config Switch1(S7)
      Boot_Config
      Boot up InterfaceSelect
      S7A
      S7B
      S7C
      0
      0
      0
      SPI NOR. (Default)
      0
      0
      1
      eMMC
      0
      1
      0
      QPIC, Parallel NAND
      0
      1
      1
      USB2.0
      1
      0
      0
      SPI-NOR-GPT
      S7D
      0
      Boot from code ram.(Default)
      1
      Boot from ROM
      Boot_Config Switch2(S9)
      Boot_Config
      0
      No auth.(Default)
      1
      Auth is required
      Interface MAP
  • Wallys has been specializing in product design & manufacturing and delivering superior OEM/ODM services in wireless communications. Dedicated to innovative designs for wireless modules. Customization is also supported, We have 90% of the world market, We're a supplier to Facebook.
  • Skype/EMAIL/Teams:sales@wallystech.com
GMT+8, 2026-10-22 19:58 , Processed in 0.023450 second(s), 10 queries , Gzip On, Redis On.
