查看: 13307|回复: 1
[供应] MX530VX Qualcomm Atheros QCA9880 Dual Band 3x3 MIMO Mini PCIE WiFi Module
签到总奖励:4金币
发表于 2023-2-24 16:19:10 | 显示全部楼层 |阅读模式
Key Features
Designed for Dual Band Wireless Access Points
2.4GHz max 21dBm & 5GHz max 20dBmoutput power (per chain)
IEEE 802.11ac compliant & backward compatible with 802.11a/b/g/n/ac
3x3 MIMO Technology, up to 1300Mbps
Mini PCI Express edge connector
Supports Spatial Multiplexing, Cyclic-Delay Diversity
(CDD), Low-Density Parity Check (LDPC) Codes, Maximal
Ratio Combining (MRC), Space Time Block Code (STBC)
Supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards
Cards are individually calibrated for Quality Assurance
Specifications
Chipset:QCA9880
Reference Design:XB140-020
Host Interface:Mini PCI Express 1.1 Standard
Operating Voltage:3.3V DC
Antenna Connector:3x U. FL
Frequency Range:2.4GHz: 2.412GHz to 2.472GHz, or 5GHz: 5.150GHz to 5.825GHz,selectable dual band
Certification:FCC & CE Certified, REACH & RoHS Compliance
Power Consumption:5W (Max)
Supported Operating System:Qualcomm Atheros reference wireless drivers or OpenWRT/LEDE with ath10k wireless drivers,
Modulation Techniques:OFDM: BPSK, QPSK, DBPSK, DQPSK, 16-QAM, 64-QAM, 256-QAM
Environmental Temperature:Operating: -20°C to 70°C, Storage: -40°C to 90°C
Environmental Humidity, non-condensing:Operating: 5% to 95%, Storage: Max. 90%
ESD Sensitivity:Class 1C
Dimensions (W × H × D):30.0mm × 50.9mm × 3.2mm
QCA9880 Wi-Fi Chipset
the QCA9880 is a popular Wi-Fi chipset produced by Qualcomm Atheros, a subsidiary of Qualcomm Inc. It is used in a variety of wireless networking devices, such as routers, access points, and gateways.
The QCA9880 chipset supports the 802.11a/b/g/n/ac Wi-Fi standards and operates in both the 2.4 GHz and 5 GHz frequency bands. It features 3x3 MIMO (Multiple Input Multiple Output) technology, which enables faster data transfer rates and improved signal quality. The chipset also supports up to 1.3 Gbps data rates and includes advanced security features such as WPA3 and 802.11i.
The QCA9880 chipset is widely used in enterprise-grade networking equipment, as well as high-performance consumer routers and access points. It is known for its reliability, performance, and versatility. The QCA9880 chipset has been widely adopted by OEMs (Original Equipment Manufacturers) and is considered to be one of the most reliable and high-performing Wi-Fi chipsets available in the market.
签到总奖励:4金币
 楼主| 发表于 2023-2-26 21:26:26 | 显示全部楼层
  长期供应wifi5模块
GMT+8, 2026-10-22 21:47 , Processed in 0.024485 second(s), 13 queries , Gzip On, Redis On.
