查看: 1402|回复: 0
[供应] IPQ6010 / wifi 6E/industrial wifi router/wallystech router/DR6018
签到总奖励:4金币
发表于 2023-3-8 12:39:06 | 显示全部楼层 |阅读模式
Breif introduction
IPQ6010 is a wireless communication SoC (systemon chip) developed by Qualcomm Technologies, Inc. DR6018 is developed on the basis of aIPQ6010,it has strong performance,it can deal withvarious scenarios in people’s lives.It features wide variety of peripheral interfaces to maximize designflexibility across a full range of home networking products.
Specifications
a Quad-core ARM 64bit A53 @1.8GHzProcessor
1GB (2x 512MB) DDR3L 16-bitinterface with 32-bit memory bus design
1 x1Gbps Ethernet Ports & POE3 x 1Gbps Ethernet Ports , 1x 2.5GbpsEthernet Port
M.2 (NGFF) “E Key” Socketwith MiniPCIe 3.0
On-board 2x2 2.4GHz MUMIMO OFDMA 802.11b/802.11g/802.11n/802.11ax, max 23dBm per chain
On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max20dBm per chain
4 x MMCXConnectors
And the nor flash is 8-32MB(normallyis 8MB),the nand flash is 256MB,the DDR is 1GB.
When we use DR6018,Noticethese point.
Thesupply voltage is 24-48V
The operating temperaturerange is -40°C to +70°C,is equal to -104°Fto +158°F
The storage temperaturerange is -45°C to +105°C,is equal to -113°Fto +221°F
The operating humidity rangeis 5% to +95% (non-condensing)
Advantages
1.high performance.It has a quad-coreARM @1.8GHz Processor,it can improveits fluency, can also provide up to 16560 DMIPScomputing power, built-in 6 multi-angle high gain antenna, 8 independent signalamplifier, to achieve 6600 megabit level of 160MH2 high frequency width.
2.strong memory.You will be able to run multiple applicationsat the same time smoothly.
3.fast datatransmission speed.It comes with two 2.4GHz radios and two 5GHz radios withfast transmission speed and stability.
If you want tolearn more about the DR6018,welcome to click the link below.
PRODUCTS_WallysCommunications (Suzhou ) Co., LTD
The companyutilizes its own professional knowledge and the top research and developmentteam unceasingly breaks through, we have the hardware, the software, the RF,the antenna, the enclosure and so on design ability.
WallysCommunications(Suzhou) Co.,Ltd,known as a specialist in researching anddeveloping and producing of wireless communication products,have star productas Routerboard,NetworkCard,Industrial Wireless AP,Antenna etc,it also is one of the suppliersof the Facebook.
Visit ourwebsite:https://www.wallystech.com/
If you’re interestedin learning more about these products, we will spare no efforts in endeavoring to be of service toyou.
GMT+8, 2026-11-3 04:34 , Processed in 0.029488 second(s), 10 queries , Gzip On, Redis On.
