查看: 2308|回复: 0
[供应] MT7915 with CPU IPQ4019/IPQ4029 to optimize wireless bandwidth allocation to ...
签到总奖励:18金币
发表于 2023-3-27 14:56:36 | 显示全部楼层 |阅读模式
Now the wireless application is gradually widespread, more places need fast, stable and cost-effective wireless solutions.
According to the survey, the combination of Qualcomm's IPQ4019/IPQ4029 and MTK's MT7915 can be the best wireless solution, and can also support multiple radio on the board and network card at the same time, which is why many wifi application projects choose their combination.
The following describes the performance and advantages of these two chips:
MT7915 introduction:
MT7915 is a Wi-Fi 6E wireless network chip from MediaTek designed to support high-speed, low-latency wireless data transmission. Wi-Fi 6E is an enhanced version of the Wi-Fi 6 standard that takes advantage of the greater broadband breadth of the 6GHz band to provide faster, more reliable wireless connections and the ability to support more devices connected at the same time.
The MT7915 chip is manufactured using a state-of-the-art 28 nm process with superior power consumption and performance balance. It supports multi-user multi-input multi-output (MU-MIMO) and Spatial Reuse based modulation to distribute wireless bandwidth optimization across multiple devices, improving the overall efficiency and throughput of the network.
In addition, MT7915 also supports Wi-Fi bands around the world, including the 2.4GHz, 5GHz and 6GHz bands, and can be compatible with different types of devices, providing users with wider wireless coverage and higher speeds.
The combination of MT7915 and Qualcomm IPQ4019 motherboards enables high-speed, stable, and reliable Wi-Fi networks, depending on the configuration and environment of the network. These two chips are excellent wireless network chips on the market, with the following characteristics:
The MT7915 chip supports the Wi-Fi 6E standard, which takes advantage of the greater broadband width of the 6GHz band to provide faster and more reliable wireless connections that can achieve higher speeds and lower latency.
IPQ4019 introduction:
The Qualcomm IPQ4019 motherboard features four high-performance ARM Cortex-A7 cpus and an efficient network accelerator for faster data transfer and higher network throughput.
Both the MT7915 chip and the Qualcomm IPQ4019 motherboard support multi-user multi-input multi-output (MU-MIMO) technology and space multiplexing technology, which can optimize the allocation of network bandwidth to multiple devices, improving the overall efficiency and throughput of the network.
Therefore, the combination of MT7915 chip and Qualcomm IPQ4019 motherboard can realize high-speed, stable and reliable Wi-Fi network, and can support the simultaneous connection of multiple devices, which can meet the needs of users in high-density network environments, such as homes, offices, hotels, shopping malls, etc. However, the specific network effect needs to be comprehensively evaluated according to the network environment, network equipment, application scenarios and other factors.
Then some people may ask, Qualcomm IPQ40xx series, there are two chips, one is IPQ4019, the other is IPQ4029, what is the difference between them?
In fact, IPQ4019 is used more at present, because it is enough to meet the needs of the project, and the price is cheaper than IPQ4029, of course, it depends on the specific needs.
The difference between IPQ4019 and IPQ4029
Qualcomm IPQ4019 and IPQ4029 are both high-performance Wi-Fi chips introduced by Qualcomm. The differences between them are mainly reflected in the following aspects:
CPU and GPU performance: The IPQ4029 is even more powerful than the IPQ4019, with a four-core Kryo 470 CPU clocking up to 2.2GHz, which is faster than the IPQ4019. In addition, the IPQ4029 is equipped with the Adreno 616 GPU for better graphics performance.
Wi-Fi performance: IPQ4029 supports higher Wi-Fi speeds and more frequency bands than IPQ4019. The IPQ4029 supports the Wi-Fi 6E standard, which provides faster and more reliable wireless connections using the 6GHz band, while the IPQ4019 does not support Wi-Fi 6E. In addition, the IPQ4029 also supports more frequency bands (including 2.4GHz, 5GHz and 6GHz), which can provide wider wireless coverage and higher speeds.
Application scenario: The IPQ4029 provides higher performance. Therefore, it is suitable for higher-end network applications, such as large-scale enterprises, high-end home networks, and public places. The IPQ4019 is suitable for mid-range network applications, such as homes, small businesses, and offices.
It should be noted that in addition to the above differences, IPQ4019 and IPQ4029 are basically the same in other aspects, such as network security, embedded applications, power consumption, etc.
If you are interested or have any questions, please contact: sales@wallystech.com
or web:https://www.wallystech.com/
Wallys is the most worth working with, as Wallys has over 10 years of experience with quaclomm WiFi chips, from ar5414 to ar7161, with full access to the chip's code.
As a result, Wallys can help customers solve many of the problems that customers encounter on WiFi.
Wallys has also developed special protocols such as time division multiple access over WiFi and fast roaming. You can run WiFi within 20km and even disable ack to extend WiFi range.
Wallys can also develop a 4.9Ghz narrow band such as 5/10Mhz.
Wallys is a professional WiFi company that can solve any technical problem you encounter, so we can help customers make many innovative products.
Wallys has a strong software team and hardware team to meet customers' various customized needs for wifi products.
GMT+8, 2026-10-24 14:04 , Processed in 0.027270 second(s), 10 queries , Gzip On, Redis On.
