查看: 2405|回复: 0
[供应] IPQ4019 IPQ4029 IPQ6010|IIOT|5G and WiFi 6:Application in Business and Industry
发表于 2023-8-29 11:08:16 | 显示全部楼层 |阅读模式
Introduction
As the world hurtles towards an era of unprecedented digital transformation, two technologies stand at the forefront, poised to reshape the landscape of business and industry: 5G and WiFi 6. These groundbreaking wireless communication technologies are not only altering the way we connect but also catalyzing profound changes across sectors. This article delves into the pivotal roles of 5G and WiFi 6 in propelling the digital transformation of business and industry. Moreover, it sheds light on their real-world applications, particularly in industrial automation and remote healthcare.
Digital Transformation in the Business Sphere
The concept of digital transformation has emerged as a driving force behind the modernization of enterprises. 5G and WiFi 6, with their unmatched speeds and connectivity capabilities, have emerged as the cornerstone technologies in this endeavor. The impact of digital transformation on business models, market dynamics, and innovation capabilities cannot be overstated.
Business Applications of 5G and WiFi 6
The integration of 5G and WiFi 6 technologies in the business realm is a transformative leap. These technologies offer lightning-fast connections, revolutionizing everything from retail experiences to financial transactions. Consider smart logistics systems that leverage these technologies for real-time tracking and optimization, or the evolution of contactless payments to intelligent, seamless transactions.
Digital Transformation in the Industrial Domain
In the realm of industry, the term "automation" has taken on new dimensions. With industries embracing digitization, 5G and WiFi 6 are emerging as indispensable enablers of smart manufacturing. Digital factories and intelligent supply chains are no longer just concepts; they are becoming tangible realities, powered by the capabilities of these wireless technologies.
Industrial Application Cases of 5G and WiFi 6
Consider a factory where machines communicate flawlessly, allowing remote monitoring and control through 5G and WiFi 6 networks. This revolutionizes production processes, enhancing efficiency and lowering costs. These technologies also ensure safer working conditions as they enable workers to manage complex tasks remotely, minimizing exposure to hazardous environments.
Conclusion
The advent of 5G and WiFi 6 marks a significant juncture in history, where the realms of business and industry are being reshaped by the relentless march of digital transformation. These technologies are not mere tools; they are the driving forces behind a new era of connectivity, efficiency, and innovation. As we navigate this path, collaboration among industries, policymakers, and technology leaders will be essential to harnessing the immense potential of 5G and WiFi 6 for the betterment of society as a whole.
Wallys 5G&WiFi Solution
5G+WiFi5
DR4019
One of the key features of the DR4019S is its powerful processor, which is a quad-core ARM Cortex-A15 CPU with a clock speed of 1.4 GHz. This processor can handle heavy network traffic and complex routing tasks with ease, ensuring smooth and fast data transfers and low latency.
The DR4019S also comes with 2 GB of DDR4 RAM and 8 GB of eMMC storage, which can be expanded with a microSD card slot. This ample amount of memory and storage allows you to store and run multiple applications and services, such as VPNs, firewalls, QoS, and more.
In terms of connectivity, the DR4019S has a rich set of ports and interfaces, including:
10 Gigabit Ethernet ports (1x SFP+ and 9x RJ45)
1 Gigabit Ethernet port (RJ45)
1 USB 3.0 port
1 serial console port
1 microUSB port (for power)
5G+WiFi6
DR6018
Website:
Youtube:
Qualcomm-Atheros IPQ6010
Quad-core ARM 64bit A53 @1.8GHz Processor
1GB DDRL3L System Memory
32MB NOR Flash, 256MB NAND Flash
Support: QUECTEL RM500Q-GL
Support: QCN9074 WiFi 6E Card
Absolute Maximum Rating
Parameter Rating Unit
Supply Voltage 24V~48 V
Operating Temperature Range -40 to +70 ºC
Storage Temperature Range -45 to +105 ºC
Operating Humidity Range5 to +95 (non-condensing) %
Hardware Specifications
Symbol Parameter CPU
CPU Frequency
Quad-core ARM 64 bit A53 @1.8 GHz processor
System Memory 1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design
Ethernet Port 1 x 1Gbps Ethernet Ports & POE3 x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port
NGFF Slot M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0
SD Card Slot 1x SD Card Slot
USB /header 1x USB 2.0 Port
POE 24V~48V passive POE/Active POE(Suport 802.3bt)
DC Jack 24V power supply
LED header FFC/FPC Connector
Serial Port 1x Serial Port 4 Pin Connector
Wireless On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax, max 23dBm per chain
On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain
4 x MMCX Connectors
Bluetooth optional
Nor Flash 8-32MB(normally is 8MB)
Nand Flash 256MB
DDR 1GB
Dimension 185mm x 116mm
Wallys Communications(Suzhou) Co.,Ltd,known as a specialist in researching and developing and producing of wireless communication products,have star product as Routerboard,Network Card,Industrial Wireless AP,Antenna etc,is one of the suppliers of the Facebook.
With the professional R&D teams which possess over 15 years experience,we could not only providing OEM/ODM/JDM services,but also have the ability to supporting customization service for you.From idea design to manufacture to put the product into market.For more information or inquiries about projects, you can contact the Wallystech team through the following channels:
GMT+8, 2026-10-22 19:10 , Processed in 0.020339 second(s), 7 queries , Gzip On, Redis On.
