查看: 1602|回复: 0
[供应] DR6018|IPQ6010 IPQ6018 WiFi6 2X2 QSDK OpenWiFi Cloud AP AC Customizable Solution
发表于 2023-9-14 16:16:25 | 显示全部楼层 |阅读模式
WiFi 6,also known as 802.11ax, represents the latest generation of wireless networking technology. It builds upon the foundation established by its predecessor, WiFi 5 (802.11ac), and brings several significant improvements to the table.
What is OpenWiFi?
OpenWiFi: An industry movement for accelerating Wi-Fi infrastructure innovation.
OpenWiFi is an open sourced, community-developed, disaggregated Wi-Fi software system. The system includes a cloud controller SDK and an Enterprise-grade Access Point (AP) firmware, designed and validated to work seamlessly together.
Support WiFi6 Hardware-Wallys
Wallys DR6018 is an industrial-grade,concurrent dual-band Wi-Fi6 Routerboard.
DR6018
Qualcomm-Atheros IPQ6010
Quad-core ARM 64bit A53 @1.8GHz Processor
1GB DDRL3L System Memory
32MB NOR Flash, 256MB NAND Flash
Support: QUECTEL RM500Q-GL
Support: QCN9074 WiFi 6E Card
Support Openwifi
Support QSDK
Absolute Maximum Rating
Parameter
Rating
Unit
Supply Voltage
24V~48
V
Operating Temperature Range
-40 to +70
ºC
Storage Temperature Range
-45 to +105
ºC
Operating Humidity Range
5 to +95 (non-condensing)
Hardware Specifications
Symbol
Parameter
CPU
CPU Frequency
Quad-core ARM 64 bit A53 @1.8 GHz processor
System Memory
1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design
Ethernet Port
1 x 1Gbps Ethernet Ports & POE3 x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port
NGFF Slot
M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0
SD Card Slot
1x SD Card Slot
USB /header
1x USB 2.0 Port
POE
24V~48V passive POE/Active POE(Suport 802.3bt)
DC Jack
24V power supply
LED header
FFC/FPC Connector
Serial Port
1x Serial Port 4 Pin Connector
Wireless
On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax, max 23dBm per chain
On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain
4 x MMCX Connectors
Bluetooth
optional
Nor Flash
8-32MB(normally is 8MB)
Nand Flash
256MB
DDR
1GB
Dimension
185mm x 116mm
https://www.wallystech.com/Routerboard/DR6018V4-wifi6-Qualcomm-IPQ6010-IPQ6018-FAMILY-2T2R-2.5G-ETH-port-supporting-5G-celluar-Modem-802-11AX-MU-MIMO-OFDMA.html
Recently, the DR6018 series routers have officially demonstrated their impressive long-distance capabilities by successfully achieving a remarkable 23 km transmission range.
Tailor your own AC+AP Solution (AP Controller) with Wallystech!
Our AC software empowers you with cross-city, cross-domain management capabilities. Customizing special functions is a breeze. Feel free to reach out to our sales team for inquiries.
Email:sales1@wallystech.com
Website:https://www.wallystech.com/
GMT+8, 2026-10-23 21:53 , Processed in 0.018054 second(s), 7 queries , Gzip On, Redis On.
