查看: 686|回复: 0
[供应] DR9274 QCN9274 QCN6274 WiFi 7 Single Band M.2 E Key Module Datasheet
发表于 2025-8-15 12:00:55 | 显示全部楼层 |阅读模式
DR9274 QCN9274 QCN6274 WiFi 7 Single Band M.2 E Key Module DatasheetOverview
The DR9274 WiFi 7 Single Band M.2 E Key module is based on the Qualcomm® QCN9274 or QCN6274 chipset, delivering exceptional wireless performance for industrial, enterprise, and embedded applications.
With Single Band (5 GHz or 6 GHz) capability and M.2 E Key form factor, it offers high-speed, low-latency connectivity optimized for modern networking solutions.
Key Features
  • Chipset Options: Qualcomm® QCN9274 or QCN6274
  • WiFi Standard: IEEE 802.11be (WiFi 7)
  • Band Support: Single Band (5 GHz or 6 GHz)
  • Form Factor: M.2 E Key
  • Interface: PCIe Gen 3
  • Modulation: Up to 4096-QAM for higher throughput
  • Security: WPA3, Enhanced Encryption
  • Industrial Temperature Range: -40°C to +85°C
Performance Advantages
  • Ultra-High Throughput – Supports up to 320 MHz channel bandwidth for faster data transfer.
  • Low Latency – Ideal for time-sensitive industrial control, AR/VR, and streaming applications.
  • Improved Spectrum Efficiency – Thanks to Multi-Link Operation (MLO) and advanced modulation.
  • Long-Range Capability – High-gain antennas and optimized RF design extend coverage.
  • Power Efficiency – Optimized for battery-powered or embedded devices.
Applications
  • Industrial Wireless APs
  • 5G/WiFi 7 Gateways
  • Smart Cities and IoT
  • AR/VR and Immersive Media
  • High-Speed Enterprise Networking
  • Embedded Systems with M.2 E Key Interface
Technical Specifications
ParameterDescription
ChipsetQCN9274 / QCN6274
StandardWiFi 7 (IEEE 802.11be)
BandSingle Band (5 GHz / 6 GHz)
InterfaceM.2 E Key, PCIe Gen 3
Channel BandwidthUp to 320 MHz
ModulationUp to 4096-QAM
Antenna ConnectorIPEX MHF4
Temperature Range-40°C to +85°C
SecurityWPA3
Why Choose Wallys DR9274 Module?
Wallys Communications specializes in custom industrial wireless solutions, offering:
  • Optimized firmware for WiFi 7 performance
  • Custom hardware design based on QCN9274/QCN6274
  • OEM/ODM/JDM services for industrial clients
  • Global technical support
Contact Us for Datasheet & Pricing:
Email: sales1@wallystech.com
Your Path to Custom Industrial Wireless AP Solutions!
GMT+8, 2026-10-23 21:39 , Processed in 0.019527 second(s), 7 queries , Gzip On, Redis On.
