查看: 13862|回复: 0
[供应] IPQ6010+QCN9074|QCN9074-6E Throughput Test Report in DR6018
发表于 2023-10-24 11:55:08 | 显示全部楼层 |阅读模式
Are you curious about the performance capabilities of the QCN9074-6E network card in the DR6018? Look no further! In this blog, we'll walk you through the hardware you'll need, how to set up one board as an Access Point (AP) and the other as a Station (STA), and perform a throughput test. Plus, we'll share our exciting conclusions.
Hardware Required:
DR6018 x2
DR9074-6E x2
Setting Up the Test:
Board Configuration: Install two DR6018 boards and two DR9074-6E network cards.
Role Assignment: Set one board as the Access Point (AP) and the other as the Station (STA).
Network Connection: Utilize the onboard 2.5G Ethernet port for connectivity.
Performing the Throughput Test:
Once the radios are linked, it's time to assess the performance:
Conclusion:
The results are nothing short of impressive. On average, the QCN9074-6E network card in the DR6018 achieves a remarkable speed of up to 1500 Mbps. Keep in mind that this speed can be even faster in better environments or when used with the IPQ8072/8074 platform.
In summary, the QCN9074-6E in the DR6018 proves to be a high-performance choice for wireless connectivity. These results showcase the potential of our products, and we're thrilled to provide you with reliable and speedy wireless solutions. Thank you for choosing Wallys wireless products!
GMT+8, 2026-10-24 01:16 , Processed in 0.029443 second(s), 8 queries , Gzip On, Redis On.
