查看: 2002|回复: 0
[供应] IPQ4019: Revolutionizing Long-Range Wireless Connectivity
发表于 2024-1-30 17:07:51 | 显示全部楼层 |阅读模式
Unveiling the IPQ4019: Revolutionizing Long-Range Wireless Connectivity
Introduction:
The IPQ4019 System-on-Chip (SoC) emerges as a game-changer for Point-to-Point (PTP) and Point-to-Multipoint (PTMP) applications, presenting advanced features tailored for routers, gateways, and access points. As the industry's pioneer single-chip Wi-Fi SoC introducing Wave-2 802.11ac capabilities, the IPQ4019 boasts a highly integrated design, seamlessly blending dual-band 11ac, sophisticated Wi-Fi features, and efficient network processing. This positions it as a stellar choice for crafting high-performance, power-efficient, and cost-effective network infrastructure products.
Key Specifications:
Ethernet:
Number of Ports: 5
CPU:
Name: 4x Arm® Cortex®-A7 Processor
Clock Speed: Up to 717 MHz
DSP:
Wi-Fi:
Peak Speed: Up to 1.733 Gbps
Generation: Wi-Fi 4, Wi-Fi 5
Standards: 802.11n, 802.11p, 802.11ac
Spectral Bands: 2.4 GHz, 5 GHz
Channels: 5 MHz, 10 MHz, 40 MHz, 20 MHz, 80 MHz
MIMO Configuration: 2x2
Spatial Streams: Up to 2
Encryption: AES-CCMP, AES-GCMP
Security: WPA, PRNG, TKIP, WPS, WAPI, WPA2, WEP
Features: TxBF, MU-MIMO, Qualcomm® Wi-Fi SON
Security:
Features: Secure Boot, Crypto Engine, Qualcomm® Trusted Execution Environment (TEE)
Memory:
Type: DDR3L
RAM Density: 1 GB
Interfaces:
Supported Interfaces: SD/eMMC, LCD, USB 2.0, UART, PCIe 2.0, SPI, Ethernet, JTAG, I²S, RGMII, I²C, USB 3.0, S/PDIF
Master I²S Modes: PCM
Universal Serial Bus (USB):
Specification Version: USB 3.0, USB 2.0
PCIe:
Specification Version: PCIe 2.0
Package:
Type: BGA
Size: 18 × 18 mm
Process Node and Technology:
Process Node: 40 nm
Wallys DR4019 - Elevating Connectivity Solutions:
Featuring the industrial-grade IPQ4019/IPQ4029 chipset, Wallys DR4019 takes long-range wireless communication to new heights. Equipped with 2x2 5G high-power Radio modules and 2x2 2.4G high-power Radio modules, it supports a wide frequency range, making it an ideal choice for diverse applications.
Key Features:
Frequency Range: 4.940GHz to 5.825GHz (5G), 2.400GHz to 2.482GHz (2.4G)
MMCX Connectors: 2 x 5G, 2 x 2.4G
Bandwidth: 5MHz/10MHz/20MHz/40MHz/80MHz
Wi-Fi Standards: 11ABGN/AC, Fixed Data Rate
RoHS Compliance for Environmental Protection
Applications:
DR4019/DR4029 with DR882: Achieving tri-band functionality for optimal performance and reduced interference in industrial projects.
DR4019/DR4029 with DR7915: Enhancing the performance of IPQ4019 and IPQ4029 with Wi-Fi 6E (802.11ax) chipset for reliable connectivity in various environments.
Software/Hardware Customization Supported:
Wallys DR40x9(IPQ4019/IPQ4029) supports open-source firmware, providing advanced customization options with OpenWRT/openwifi. Leveraging this compatibility allows users to tailor a powerful Wi-Fi solution to meet specific needs.
Wallystech's Expertise:
Wallystech, a distinguished research and development company specializing in Linux and WiFi protocols, brings over a decade of expertise. Focus on software/hardware modifications on Qualcomm chipset embedded board, coupled with proficiency in driver and kernel development and hardware design, ensures a comprehensive and flawless solution.
For more information, contact Wallystech:
Website: https://www.wallystech.com/
GMT+8, 2026-3-16 10:38 , Processed in 0.069717 second(s), 10 queries , Gzip On, MemCached On.
