查看: 2220|回复: 0
[供应] Wallys' Wi-Fi 6 Routerboard Offering: A Comprehensive Guide IPQ5018-IPQ6010-IPQ6
发表于 2024-2-22 13:38:28 | 显示全部楼层 |阅读模式
Wallys' Wi-Fi 6 Routerboard Offering: A Comprehensive Guide IPQ5018-IPQ6010-IPQ6018-IPQ8072-IPQ8074
Wallys, a trailblazer in connectivity solutions, unveils a range of cutting-edge WiFi 6 router boards tailored to meet various requirements. Now, let's explore the intricacies of WiFi 6 router boards and analyze their specifications with informative data sheets.
1.DR5018-IPQ5018 WiFi 6 Routerboard with 2.4GHz and BT5.1 Support
The DR5018 is an enterprise-grade wireless module designed for high-bandwidth applications in challenging environments. Key features include:
BT5.1 Radio module integration
2x2 2.4GHz high-power Radio module
Dual-core ARM 64bit A53 processor clocked at 1.0GHz
512MB DDR L3L system memory
4MB NOR Flash and 128MB NAND Flash storage
Onboard 2.4GHz radio supporting up to 573Mbps data rates
M.2 card slots for QUECTEL RM 500Q-GL 5G module and QCN9074 WiFi 6E card
Openwifi support for enhanced flexibility and compatibility
This routerboard also have a SOM versionR5018M
https://www.wallystech.com/Routerboard/DR5018M-wifi6-Qualcomm-IPQ5018-2T2R-2.5G-ETH-port-802.11AX-MU-MIMO-OFDMA-supporting-QCN9074-QCN6122-QCN6102-wifi-card.html
2.DR6018-IPQ6010 WiFi 6 Routerboard with Dual-Band Support
The DR6018 is a high-performance router board equipped with advanced features for seamless connectivity. Key features include:
Qualcomm-Atheros IPQ6010 chipset
Quad-core ARM 64bit A53 processor running at 1.8GHz
1GB DDRL3L system memory for efficient multitasking
32MB NOR Flash and 256MB NAND Flash storage for data storage
Supports Dynamic Frequency Selection (DFS) for optimized wireless performance
2x2 On-board 2.4GHz radio with up to 573Mbps physical data rate
2x2 On-board 5GHz radio with up to 1201Mbps physical data rate
Compatibility with QUECTEL RM500Q-GL for 5G connectivity
Support for QCN9074 WiFi 6E Card for enhanced wireless capabilities
Openwifi support for flexibility and compatibility
QSDK support for development and customization
This routerboard also have several version:
DR6018CR6018 with SFP port
DR6018SR6018 with less eth port
3.DR8072-IPQ8072 Dual-Band WiFi 6 Routerboard
The DR8072 boasts powerful features for robust connectivity. Key highlights include:
Qualcomm Atheros IPQ8072A AR Quad Core CPU for efficient processing
On-board 5GHz radio with up to 2475 Mbps physical data rate
On-board 2.4GHz radio with up to 1147Mbps physical data rate
8 MB NOR Flash and 256MB NAND Flash storage (Optional NAND Flash upgrade to 1GB)
Support for 11ax TX Beamforming, MU-MIMO DL and UL, and OFDMA DL and UL for optimized wireless performance
Dynamic Frequency Selection (DFS) support for improved spectrum utilization
1GB DDR3L system memory (Optional DDR3L upgrade to 2GB)
M.2 connector compatibility for QCN9074 production module support
4.DR8074-IPQ8074 WiFi 6 Routerboard with 2.4GHz Support
The DR8074 is a high-performance router board designed for demanding networking applications. Key features include:
Qualcomm Atheros IPQ8074A AR Quad Core CPU for robust processing power
On-board 5GHz radio with up to 4804Mbps physical data rate
Support for 11ax TX Beamforming for enhanced signal strength
Support for 11ac/ax MU-MIMO DL and UL for efficient multi-user communication
Support for OFDMA DL and UL for improved spectral efficiency
Tri-band support with 5G SBS (4x4/5GHz + 4x4/5GHz) + 4x4/2.4GHz for versatile connectivity options
Dynamic Frequency Selection (DFS) support for optimized wireless performance
Wallys' WiFi 6 routerboard are engineered for versatility and reliability, making them ideal for Enterprise, Industrial, Cybersecurity, Transportation, and SMB applications.
Inquiries:
Wallys is dedicated to continuous innovation, constantly pushing the boundaries of WiFi technology. In addition to its hardware products, Wallys also offers a range of ODM/OEM services, including:
Customization: Wallys can customize its WiFi 6 products and embedded boards to meet the specific needs of its customers.
Engineering support
Testing and certification
For inquiries or to discuss your specific requirements, please contact our dedicated sales team at sales1@wallystech.com.
Wallys - Empowering Connectivity, Driving Innovation.
GMT+8, 2026-9-18 20:08 , Processed in 0.072109 second(s), 12 queries , Gzip On, MemCached On.
