查看: 1851|回复: 0
[供应] Introducing the DR5018M: Advanced, Cost-Effective IPQ5018 Wireless Solutions
发表于 2024-5-21 15:39:36 | 显示全部楼层 |阅读模式
The DR5018M sets a new standard in wireless communication solutions, combining advanced technology with cost-effectiveness. Designed for flexibility and high performance, this router board is ideal for a wide range of applications, from home and office setups to custom commercial products.
Technical Specifications:
- Processor: Qualcomm-Atheros IPQ5018 Dual-core ARM 64-bit A53 @ 1.0GHz
- Memory: 512MB DDR3L with 16-bit interface and 32-bit memory bus design
- Storage: 8MB NOR Flash, 128MB NAND Flash
- Ethernet:
  - Version 1: 2 x 1Gbps Ethernet Ports
  - Version 2: 1 x 1Gbps Ethernet Port, 1 x 2.5Gbps PoE Port
- PCIe 3.0: 1x PCIEx2 Interface
- SGMII: 1x SGMII Interface
- UART: 1x UART Interface
- GPIO: 13 x GPIOs
- Wireless:
  - On-board 2x2 2.4GHz MU-MIMO OFDMA supporting 802.11b/g/n/ax, max 21dBm per chain with 2x IPEX Connectors
  - Another version with 2x MMCX Connectors
- Power Output: 5VDD
- Dimensions: 60mm x 40mm
Expansion and Customization Options:
The DR5018M features multiple M.2 card slots for extensive customization, supporting:
- 5G (QUECTEL RM500Q-GL)
- QCN9074 Wi-Fi 6E Card
- QCN6122-6E Card
- QCN6102-5G Card
Performance and Reliability:
Engineered for robust performance, the DR5018M excels in point-to-point (PTP) applications, delivering impressive throughput in real-world tests:
3.3KM PTP Test:
- 5GHz: 949Mbps
- 6GHz: 821Mbps
1.5KM PTP Test:
- 5GHz: 1.5Gbps
- 6GHz: 1Gbps
Versatility for Various Applications:
The DR5018M is perfect for diverse environments and uses. Its modular design supports a wide range of applications, including:
- Custom low-cost outdoor access points
- Customer Premises Equipment (CPE)
- Smart vending machines
- Ticket stations
- Home and office networks
- Homelabs
Future-Proof and Scalable:
Designed with future firmware updates in mind, the DR5018M ensures long-term usability and support for the latest technologies. Its versatile connectivity options and robust performance make it an ideal choice for future-proof, scalable solutions.
Explore the Possibilities:
With the DR5018M, you are investing in a high-performance, customizable, and cost-effective wireless communication solution. Whether you're enhancing your current setup or developing new products, the DR5018M offers the power and flexibility you need.
Discover the DR5018M and elevate your wireless communication capabilities. Experience the perfect blend of advanced technology and cost-efficiency for all your wireless needs.
Contact Wallys Sales team for learn more: sales1@wallystech.com
GMT+8, 2026-11-23 09:03 , Processed in 0.023523 second(s), 7 queries , Gzip On, Redis On.
