查看: 527|回复: 0
[供应] QCN9274 & QCN6274: Powering the Next Generation of Wi-Fi 7 Connectivity
发表于 2025-5-15 11:15:59 | 显示全部楼层 |阅读模式
Wi-Fi 7 is no longer just a buzzword — it’s a performance revolution. At the heart of this transformation are two powerful Qualcomm radio chipsets: QCN9274 and QCN6274.
🔍 QCN9274: High-End PCIe Radio for Demanding Environments
  • 4x4 MIMO, supports up to 320 MHz channel width
  • Multi-Link Operation (MLO) enabled
  • Dual-band: 2.4 GHz + 5/6 GHz (6 GHz optional)
  • Ultra-low latency, ideal for video streaming, industrial backhaul, and enterprise APs
  • Compatible with Wallys router boards like IPQ5332, IPQ9574, and IPQ8072
🔍 QCN6274: Cost-Effective Wi-Fi 7 Entry Module
  • 2x2 MIMO, lower power draw
  • Dual-band with 160 MHz support
  • Perfect for consumer APs, IoT gateways, or compact enterprise solutions
  • Optimized pairing with IPQ5018, IPQ6010, and IPQ5322
🧩 Wallys Hardware Compatibility
We’ve validated both modules with a range of high-performance router boards:
  • IPQ4019 / IPQ4029 — for legacy Wi-Fi 5/6 upgrades
  • IPQ5018 / IPQ6010 — mainstream Wi-Fi 6
  • IPQ8072 / IPQ9574 / IPQ5332 — high-end Wi-Fi 6/7 platforms
💼 Wallys: Your Wi-Fi 7 ODM Partner
  • Custom firmware support (OpenWrt, QSDK with MLO)
  • OEM/ODM router board + radio module integration
  • Enclosure design, thermal tuning, and antenna matching
  • Rapid prototyping, calibration and testing services
📨 Contact: sales1@wallystech.com
🌐 Learn more: www.wallystech.com
Data is for reference only. For detailed test reports and bulk order inquiries, please contact us.
GMT+8, 2025-9-3 03:36 , Processed in 0.137997 second(s), 13 queries , Gzip On, MemCached On.
