查看: 94|回复: 0
[供应] DR5322: Industrial-Grade Edge Gateway Powered by IPQ5322 + Wi-Fi 7
发表于 2025-5-22 10:21:47 | 显示全部楼层 |阅读模式
As smart factories, logistics, and industrial automation push for higher throughput and lower latency, Wi-Fi 7 is rapidly emerging as the backbone for next-generation wireless infrastructure. At the center of this evolution is the Wallys DR5322, a compact, rugged, and efficient router board designed for edge computing and industrial gateways.
🔧 DR5322 at a Glance
  • Qualcomm IPQ5322 SoC – powerful, stable, and cost-efficient
  • 1GB DDR4 (16-bit) – faster data processing for real-time edge computing
  • 10G SFP Port – reliable fiber uplink for factory backbone or campus networks
  • Mini PCIe & M.2 slots – supports flexible expansion, including 5G modules
🚀 Wi-Fi 7 Industrial Module Options
To meet diverse industrial needs, Wallys recommends:
  • QCN9274 (4x4 MIMO, Wi-Fi 7) – for high-throughput, multi-device environments
  • QCN6274 (2x2 MIMO, low-power) – for compact IoT/edge devices
  • MT7915 / MT7916 – cost-effective Wi-Fi 6 solution
  • 5G module (via M.2) – for hybrid wired + wireless deployments
🏭 Ideal Use Cases
  • Smart factory wireless AP or controller
  • Port and warehouse surveillance backhaul
  • Wi-Fi 7-based industrial IoT edge node
  • High-speed data acquisition systems
  • Remote access points for mining, construction
🔩 Wallys Value-Added Services
We understand industrial deployment needs more than hardware. That’s why we offer:
✔ Customized enclosure & thermal solutions
✔ Driver support & firmware pre-integration
✔ Long-term supply & BOM optimization
✔ OEM/ODM/JDM cooperation
📨 Email: [url=]sales1@wallystech.com[/url]
🔗 Website: www.wallystech.com
Data is for reference only. For full technical documentation and test results, contact our team directly.
GMT+8, 2025-6-6 23:57 , Processed in 0.240058 second(s), 14 queries , Gzip On, MemCached On.
