查看: 587|回复: 0
[供应] IPQ9554 and IPQ9570: Comparing Qualcomm’s Dual-Band and Tri-Band SoCs
发表于 2025-11-12 11:39:22 | 显示全部楼层 |阅读模式
As Wi-Fi 7 technology reshapes the networking industry, Qualcomm continues to lead with its high-performance networking solutions. Among its new generation of SoCs, the IPQ9554 and IPQ9570 stand out as two powerful options designed for next-generation routers, access points, and industrial wireless systems.
While both are part of Qualcomm’s Networking Pro Series, they target slightly different performance and application scenarios — one optimized for dual-band efficiency, and the other for tri-band throughput and multi-link operations. Let’s explore how they differ and what each brings to the table.
1. Overview of Qualcomm IPQ9554
The Qualcomm IPQ9554 is a dual-band Wi-Fi 7 SoC, ideal for enterprise and industrial applications that demand robust performance but within moderate power and cost budgets.
Key features include:
  • Wi-Fi 7 dual-band support (2.4GHz + 5GHz)
  • Quad-core ARM Cortex-A73 CPU, clocked up to 2.2GHz
  • Qualcomm’s Multi-Link Operation (MLO) for seamless multi-band connection
  • Support for 320 MHz channels and 4096-QAM modulation
  • Enhanced OFDMA and MU-MIMO capabilities
  • PCIe Gen 3 interfaces for external Wi-Fi or Ethernet expansion
This SoC is widely used in industrial gateways, enterprise routers, and smart city networks, where reliability and stable performance are top priorities.
2. Overview of Qualcomm IPQ9570
The IPQ9570 is a tri-band Wi-Fi 7 SoC, offering a significant leap in throughput and network flexibility compared to dual-band platforms.
Key specifications:
  • Tri-band support (2.4GHz + 5GHz + 6GHz)
  • Quad-core ARM Cortex-A73 CPU, up to 2.2GHz
  • Integrated network accelerator for high data throughput
  • Multi-Link Operation (MLO) and Multi-RU support for better latency control
  • Support for up to 16 spatial streams (4x4 per band)
  • Designed for high-density environments and multi-device connectivity
The IPQ9570 is ideal for premium routers, mesh systems, and industrial backhaul links requiring wide coverage and multi-gigabit performance.
3. IPQ9554 vs IPQ9570: Feature ComparisonFeatureIPQ9554IPQ9570
Wi-Fi BandsDual-band (2.4GHz + 5GHz)Tri-band (2.4GHz + 5GHz + 6GHz)
CPUQuad-core Cortex-A73Quad-core Cortex-A73
Channel WidthUp to 320 MHzUp to 320 MHz
Multi-Link Operation (MLO)SupportedSupported
Target ApplicationsIndustrial AP, Enterprise RouterHigh-performance AP, Tri-band Router, Mesh Node
Wi-Fi StreamsUp to 8Up to 16
Power ConsumptionLowerHigher (for higher throughput)
ThroughputUp to 10 Gbps (theoretical)Up to 20 Gbps (theoretical)
In short, IPQ9554 focuses on efficiency and cost-effectiveness, while IPQ9570 delivers unmatched speed and connectivity for demanding environments.
4. Industrial and Commercial Applications
  • IPQ9554: Commonly used in smart city networks, IoT gateways, industrial APs, and medium-density enterprise solutions.
  • IPQ9570: Designed for data-heavy networks, tri-band CPEs, backhaul systems, and multi-AP mesh networks that require high-speed, low-latency connections.
Both SoCs are compatible with Qualcomm’s Networking Pro 620 platform, allowing system designers to build flexible Wi-Fi 7 hardware with advanced management and security features.
5. Wallys Wi-Fi 7 Solutions Based on Qualcomm IPQ Platforms
As a long-term Qualcomm partner, Wallys Communications offers industrial-grade router boards and wireless modules based on the IPQ9554, IPQ9570, and IPQ9574 SoCs.
Our boards are designed for:
  • Custom firmware and OpenWrt support
  • Extended temperature operation
  • OEM/ODM and JDM flexibility
  • Optimized RF design for industrial applications
If you’re developing Wi-Fi 7 solutions for enterprise or industrial networks, Wallys’ hardware platforms can help you reduce time-to-market and achieve reliable high-speed wireless performance.
📩 Contact WallysTo learn more about Wallys Wi-Fi 7 solutions based on Qualcomm IPQ9554 and IPQ9570, please reach out to our sales team:
📧 Email: [url=]sales1@wallystech.com[/url]
🌐 Website: www.wallystech.com
GMT+8, 2026-10-23 20:58 , Processed in 0.017762 second(s), 7 queries , Gzip On, Redis On.
