查看: 434|回复: 0
[供应] Real-World Application: Building Long-Range Outdoor Links with DR9574 + QCN9274
发表于 2025-11-14 10:58:15 | 显示全部楼层 |阅读模式
As industries demand faster, more stable, and longer-distance wireless connectivity, Wi-Fi 7 platforms are becoming the preferred choice for outdoor point-to-point (PtP) and point-to-multipoint (PtMP) deployments.
In this article, we explore how the Wallys DR9574 router board, combined with the Qualcomm QCN9274 Wi-Fi 7 radio, delivers exceptional long-range outdoor performance, high throughput, and robust reliability for real-world industrial applications.
Why DR9574 + QCN9274 Is Ideal for Long-Range Outdoor Links1. Wi-Fi 7 MLO for Ultra-Stable Links
The QCN9274 supports Multi-Link Operation (MLO), enabling simultaneous data transmission over multiple bands.
Benefits include:
  • Lower latency across long distances
  • Improved link resilience under interference
  • Higher aggregated throughput for demanding applications
This is especially valuable for outdoor links exposed to noise, weather, and dynamic RF environments.
2. Long-Range Optimized Hardware Design
The Wallys DR9574 uses Qualcomm’s IPQ9574 platform and provides:
  • High-gain antenna support
  • Industrial-grade power design
  • Multiple PCIe slots for high-performance Wi-Fi 7 cards such as the QCN9274
  • Excellent heat dissipation for outdoor enclosures
These features ensure stable operation even in harsh climates.
3. High Throughput for Bandwidth-Intensive Applications
With the QCN9274’s 4x4 MU-MIMO and 320 MHz channel width, users can achieve:
  • Gigabit-level wireless backhaul
  • High-speed CCTV/Video streaming
  • Fast data offloading between remote sites
This makes the solution suitable for modern high-capacity outdoor networks.
Real-World Application Scenarios✔ Smart City Infrastructure
Deploy DR9574 + QCN9274 on rooftops to create long-distance wireless bridges for:
  • Traffic cameras
  • Environmental monitoring
  • Public Wi-Fi zones
✔ Industrial Facilities & Warehouses
Use the link to connect:
  • Remote entry gates
  • Storage yards
  • Automated equipment requiring stable low-latency control
✔ Farms, Mines, and Oil Fields
Provides reliable connectivity where fiber is too expensive or impossible to deploy.
✔ Surveillance Networks
Perfect for transmitting high-resolution video from:
  • Remote poles
  • Security towers
  • Highway monitoring sites
Key Technical AdvantagesFeatureBenefit for Outdoor Links
Wi-Fi 7 (802.11be)Higher throughput & improved RF efficiency
MLO TechnologyStable connectivity even over long distance
4x4 MU-MIMOSupports large data flows and multiple devices
320 MHz channelsMaximizes speed in open outdoor spectrum
Industrial-grade PCBReliable in extreme temperatures
PCIe expansionSupports QCN9274 and other high-power radios
Deployment Tips for Long-Range Links
To achieve the best real-world performance:
1. Use High-Gain Directional Antennas
Pair with:
  • 25–30 dBi parabolic dish
  • High-gain horn for PtMP
2. Ensure Clear Line of Sight
Avoid:
  • Trees
  • Buildings
  • Water surfaces (may cause reflections)
3. Optimize Channel Selection
Use:
  • DFS bands for lower noise
  • 6 GHz where regulation allows
4. Enable MLO Smart Routing
MLO dynamically selects the best band for real-time traffic.
Why Choose Wallys DR9574 for Outdoor Wi-Fi 7 Projects?
Wallys provides:
  • Industrial-grade router boards
  • Custom firmware support (OpenWrt / QSDK-based)
  • Long-term supply availability
  • Hardware/Software customization for OEM & ODM projects
Our DR9574 + QCN9274 combination is already used in outdoor wireless backhaul, security networks, and enterprise bridging projects worldwide.
Explore Wallys DR9574 Solutions
If you're building long-range Wi-Fi 7 outdoor links and need:
  • Hardware samples
  • Custom firmware
  • Design advice
  • High-power radio recommendations
Wallys can support your full project development.
📩 Contact our team: [url=]sales1@wallystech.com[/url]
🔗 Learn more about Wallys Wi-Fi 7 hardware solutions
GMT+8, 2026-11-15 00:51 , Processed in 0.023901 second(s), 8 queries , Gzip On, Redis On.
