查看: 420|回复: 0
[供应] QCN9024 Wi-Fi 6 Chip Overview for Industrial & Enterprise NIC Designs
发表于 2025-12-11 16:46:51 | 显示全部楼层 |阅读模式
The Qualcomm QCN9024 is a high-performance Wi-Fi 6 (802.11ax) radio chip widely adopted in next-generation wireless NICs and embedded wireless modules. With support for 2.4GHz, 5GHz, and 6GHz, the QCN9024 offers exceptional flexibility for developing single-band, dual-band, and tri-band Wi-Fi network cards used in industrial, enterprise, and high-density environments.
This comprehensive guide explains the capabilities of the QCN9024 chipset and how Wallys Communications leverages it to deliver a full lineup of professional Wi-Fi 6 and Wi-Fi 6E NIC solutions.
⭐ What Is the Qualcomm QCN9024?
The QCN9024 is a robust 4×4 Wi-Fi 6 chip featuring:
  • 2.4G / 5G / 6G multi-band capability
  • 160 MHz bandwidth
  • 4×4 MU-MIMO (uplink + downlink)
  • 1024-QAM modulation
  • OFDMA & TWT for high-efficiency scheduling
  • Industrial-grade reliability and long-range RF performance
Its configurable multi-band design allows manufacturers to build:
  • 2.4 GHz Wi-Fi NICs
  • 5 GHz Wi-Fi NICs
  • 6 GHz Wi-Fi 6E NICs
  • Dual-band NICs (e.g., 2G+5G or 5G+6G)
  • Tri-band NICs (2G+5G+6G)
This makes QCN9024 an ideal foundation for flexible product development.
⭐ Key Features of QCN9024
1. Multi-Band Configurability
One chip enables multiple product lines—single, dual, or tri-band—greatly reducing R&D time and cost.
2. Full Wi-Fi 6 Feature Set
Including:
  • OFDMA for dense environments
  • MU-MIMO for simultaneous multi-user throughput
  • TWT for power-saving IoT applications
  • Beamforming for enhanced range and stability
3. Industrial Reliability
Designed to perform consistently in:
  • Factories
  • Warehouses
  • Robotics systems (AGV/AMR)
  • Outdoor CPE
  • Long-range industrial bridges
4. Ideal for PCIe/M.2/miniPCIe NIC Designs
The QCN9024 is widely used in:
  • PCIe Wi-Fi NICs
  • M.2 Key E / Key A+E cards
  • miniPCIe wireless mods
  • Custom embedded platforms
⭐ Applications of QCN9024-Based Modules
✔ Enterprise Wi-Fi 6 APs
High-density deployments require strong multi-user concurrency, which QCN9024 delivers.
✔ Industrial Wireless Systems
Stable connectivity for machines, AGVs, AMRs, and automation control.
✔ Outdoor CPE & Backhaul
Excellent sensitivity and long-distance RF reach.
✔ Custom Router Boards
Many embedded hardware developers integrate QCN9024 for tailored Wi-Fi projects.
⭐ Wallys QCN9024 Wi-Fi 6 NIC Lineup
Wallys Communications offers a complete, industrial-grade NIC product family based on the QCN9024 chipset, providing broad frequency coverage and customization options for OEM/ODM clients.
以下为你更新后的 完整产品线介绍:
🔶 DR9074 Series (Standard Wi-Fi 6 NICs)
Wallys DR9074 基于 QCN9024,可提供单频三种版本:
1) DR9074-2G
  • 2.4GHz Wi-Fi 6
  • 4×4 MIMO
  • Long-distance, high-stability industrial coverage
  • Ideal for IoT gateways & industrial routers
2) DR9074-5G
  • 5GHz Wi-Fi 6
  • High throughput for enterprise APs
  • Low latency, strong anti-interference
3) DR9074-6G (Wi-Fi 6E)
  • Supports the 6GHz band (Wi-Fi 6E)
  • Ideal for low-latency, ultra-clean spectrum applications
  • Perfect for dense office environments and modern APs
🔷 DR9074E Series (Enhanced Dual-Band NICs)
Wallys DR9074E 提供 增强型射频设计 + 更好的散热设计,并有两个版本:
1) DR9074E-2G5G
  • Dual-band 2.4G + 5G
  • Suitable for enterprise APs and industrial roaming systems
2) DR9074E-5G6G
  • Dual-band 5G + 6G
  • Ideal for Wi-Fi 6E APs requiring both legacy and next-gen band support
Enhanced series benefits:
  • Improved RF sensitivity
  • Higher thermal stability
  • Shock/vibration-resistant industrial design
🔶 DR9074-Triband (True Tri-Band Wi-Fi 6/6E NIC)
✔ One card with 3 radios: 2.4G + 5G + 6G
Perfect for:
  • Tri-band enterprise APs
  • Advanced mesh nodes
  • Wi-Fi 6E routers
  • Multi-channel low-latency systems
Tri-band architecture enables:
  • Separate backhaul & client bands
  • Reduced contention
  • Higher system capacity
  • Better roaming & mesh performance
This is Wallys’ flagship Wi-Fi 6E NIC solution.
⭐ Why Choose Wallys QCN9024 Solutions?
  • Industrial-grade PCB + RF optimization
  • Mature driver support (ath11k, OpenWrt, QSDK, Ubuntu)
  • Long-distance transmission optimization
  • OEM / ODM / JDM customization available
  • Custom firmware (Mesh, Roaming, special protocol optimization)
  • Professional technical support for AP/CPE vendors
Wallys solutions are actively deployed in:
  • Warehousing
  • Smart city networks
  • Industrial automation
  • Transportation systems
  • Telecom-grade CPE and gateways
📩 Contact Wallys Communications
Email: [color=var(--MapLink)]sales1@wallystech.com Slogan: Your Path to Custom Industrial Wireless AP Solutions!
Our engineering and sales teams are ready to support your Wi-Fi 6 / Wi-Fi 6E development projects.
GMT+8, 2026-11-3 06:29 , Processed in 0.017877 second(s), 7 queries , Gzip On, Redis On.
