查看: 24977|回复: 14
[量产相关] CSR8670方案高品质音效寻求合作厂家
发表于 2014-5-12 16:12:14 | 显示全部楼层 |阅读模式
立体声,同时连接两个手机自动切换
立体声输出,支持line in 音量加减低功耗,,内置DSP,支持音乐与通话功能,内置天线,体积超小。
boomtech半导体有限公司,蓝牙4模块的先锋
BT1212 which is a high performance, cost effective, low power and compact solution.
bt1212是一种高性能,低功耗和成本有效的,紧凑的解决方案。
The Bluetooth module provides a complete 2.4GHz Bluetooth system
蓝牙模块提供了一个完整的2.4GHz蓝芽系统
BlueCore® CSR8670™ BGA consumer audio platform for wired and wireless applications
BlueCore®csr8670™BGA消费音频平台为有线和无线应用
integrates an ultralow-power DSP and application processor with embedded flash memory,
集成了一个超低功耗DSP与Flash存储器的嵌入式应用处理器,
a high-performance stereo codec, a power management subsystem,
一种高性能的立体声编解码器,一个电源管理子系统,
LED and LCD drivers and capacitive touch sensor inputs in a SoC IC.
LED在IC LCD驱动器和电容式触摸传感器输入。
The enhanced Kalimba DSP coprocessor with 80MIPS supports enhanced audio and
增强的Kalimba DSP协处理器支持增强音频和80mips
DSP applications.
DSP的应用。
2. Key Features
2。关键特征
• Fully Qualified Single-chip Bluetooth® v4.0 System
•完全合格的单芯片蓝牙®V4.0系统
• Receiver sensitivity: -90dBm (basic rate) and -92dBm(EDR)
•接收机灵敏度:- 90dbm(基本速率)和92dbm(EDR)
• 10dBm RF transmit power with level control from on‑chip 6‑bit DAC
与水平控制在‑芯片6‑位DAC•射频发射功率10dBm
• Support for CSR's latest CVC technology for narrow-band and wideband voice
•支持CSR的最新CVC技术用于窄带和宽带语音
connections including wind noise reduction
连接包括风噪声减小
• Stereo codec with 2 channels of ADC and up to 6 microphone inputs
•立体声编解码器的ADC通道2和6的麦克风输入
(includes bias generators and digital microphone support)
(包括偏置发生器和数字麦克风支持)
• Multipoint HFP connection to 2 phones for voice
•多点HFP连接2手机的声音
• Multipoint A2DP connection enables a headset(A2DP) connection to 2 A2DP
•多点A2DP连接使得耳机(蓝牙)蓝牙连接2
source devices for music playback
音乐播放源装置
• Audio interfaces: I²S PCM and SPDIF
•音频接口:我²的PCM和SPDIF
• aptX, SBC, MP3 and AAC decoder support
•APTX,SBC,MP3和AAC解码器的支持
• Serial interfaces: UART, USB 2.0 full-speed, I²C
•串行接口:UART,USB 2全速,我²C
Supported sample rates of 8, 11.025, 16, 22.05, 32,44.1, 48 and 96kHz (DAC only)
支持采样率为8,11.025,16,22.05,48和32,44.1,96kHz(DAC只)
■Bluetooth low energy
■蓝牙低能量
•Dual-mode Bluetooth low energyradio
•双模蓝牙低energyradio
•Support for Bluetooth basic rate / EDR and low energyconnections
•支持基本速率/蓝牙EDR和低energyconnections
•3 Bluetooth low energyconnections at the same time as basic rate A2DP
•3蓝牙低energyconnections时间作为基本速率A2DP相同
• Slim module with 19mm x 12mm x 2.0mm
•超薄模块与19毫米x 12mm×2.0mm
• RoHS Compliant
•符合RoHS
3. Applications
3。应用
• Smart remote controllers
•智能遥控器
• Wired or wireless soundbars
•有线或无线soundbars
• Wired or wireless speakers and headphones
•有线或无线耳机
• Wearable audio (on-the-go)
•耐磨音频(上)
• Wearable audio with sensors (health and wellbeing applications)
•耐磨音频传感器(健康和福祉的应用程序
如果您有功放ICNFC蓝牙模块、音频解码模组、苹果周边设备方案解决及其他软件方案解决需要话,请与我们联系,我们会为您提供样板和报价。谢谢!
姓名:李爽
电话:18898795323
QQ2995949649
地址:深圳市宝安区西乡固戍愉盛工业园66
签到总天数:164天
签到总奖励:1764金币
发表于 2014-5-13 00:18:19 | 显示全部楼层
CSR8670可以做些什么????
签到总奖励:113金币
发表于 2014-5-13 08:17:09 | 显示全部楼层
学习学习学习
 楼主| 发表于 2014-5-13 17:43:50 | 显示全部楼层
岁月 发表于 2014-5-13 00:18
CSR8670可以做些什么????
板面我有发的有规格,你可以参考一下,适合高端音频输出,用于高端音箱,耳机方面
签到总天数:14天
签到总奖励:97金币
发表于 2014-5-20 21:49:54 | 显示全部楼层
高端音频输出?现在又APTX的音频发射么?
 楼主| 发表于 2014-5-21 10:44:24 | 显示全部楼层
8670本来就是支持这些的
签到总天数:14天
签到总奖励:97金币
发表于 2014-5-21 21:58:12 | 显示全部楼层
好像都是接收支持APTX耶,发射都是SBC
 楼主| 发表于 2014-5-22 09:01:53 | 显示全部楼层
只有CSR8645和8670支持APTX功能,8635,8615这些都是不支持的
签到总天数:102天
签到总奖励:1838金币
发表于 2014-6-6 14:26:45 | 显示全部楼层
8670可以做到音频控制跟蓝牙自拍器共存吗?
 楼主| 发表于 2014-6-6 17:14:20 | 显示全部楼层
可以做到的
GMT+8, 2025-6-4 04:04 , Processed in 0.140449 second(s), 23 queries , Gzip On, MemCached On.
