查看: 14291|回复: 4
[ADK相关资料] ADK2.5.1 I2S输出时钟问题
发表于 2014-6-17 16:28:01 | 显示全部楼层 |阅读模式
ADK2.5.1  csr_i2s_audio_plugin.c 中:
Sink CsrI2SAudioOutputConnect(uint32 rate, bool stereo, Source left_port, Source right_port)
    /* obtain sink to I2S interface */
    Sink lSink_A = StreamAudioSink(AUDIO_HARDWARE_I2S, AUDIO_INSTANCE_0, AUDIO_CHANNEL_SLOT_1 );
    /* configure the I2S interface operating mode, run in master mode */
    PanicFalse(SinkConfigure(lSink_A, STREAM_I2S_MASTER_MODE, TRUE));
    /* set the sample rate of the dsp audio data */
    PanicFalse(SinkConfigure(lSink_A, STREAM_I2S_MASTER_CLOCK_RATE, (rate * MCLK_SCALING_FACTOR)));   //rate :48k, CLK_SCALING_FACTOR    默认256
    PanicFalse(SinkConfigure(lSink_A, STREAM_I2S_SYNC_RATE, rate));
    /* left justified i2s data */
    PanicFalse(SinkConfigure(lSink_A, STREAM_I2S_JSTFY_FORMAT, 0));
    /* MSB of data occurs on the second SCLK */
    PanicFalse(SinkConfigure(lSink_A, STREAM_I2S_LFT_JSTFY_DLY, 1));
    /* data is LEFT channel when word clock is high */
    PanicFalse(SinkConfigure(lSink_A, STREAM_I2S_CHNL_PLRTY, 0));
    /* number of data bits per sample, 16 */
    PanicFalse(SinkConfigure(lSink_A, STREAM_I2S_BITS_PER_SAMPLE, 16));
    /* if STEREO mode configured then connect the output channel B */
    if(stereo)
        /* obtain sink for channel B I2S interface */
        Sink lSink_B = StreamAudioSink(AUDIO_HARDWARE_I2S, AUDIO_INSTANCE_0, AUDIO_CHANNEL_SLOT_0 );
        PanicFalse(SinkConfigure(lSink_B, STREAM_I2S_MASTER_MODE, TRUE));
        /* set the master clock rate of the dsp audio data, this is  */
        PanicFalse(SinkConfigure(lSink_B, STREAM_I2S_MASTER_CLOCK_RATE, (rate * MCLK_SCALING_FACTOR)));
        PanicFalse(SinkConfigure(lSink_B, STREAM_I2S_SYNC_RATE, rate));
        PanicFalse(SinkConfigure(lSink_B, STREAM_I2S_JSTFY_FORMAT, 0));
        PanicFalse(SinkConfigure(lSink_B, STREAM_I2S_LFT_JSTFY_DLY, 1));
        PanicFalse(SinkConfigure(lSink_B, STREAM_I2S_CHNL_PLRTY, 0));
        PanicFalse(SinkConfigure(lSink_B, STREAM_I2S_BITS_PER_SAMPLE, 16));
        /* synchronise both sinks for channels A & B */
        PanicFalse(SinkSynchronise(lSink_A, lSink_B));
        /* connect dsp ports to i2s interface */
        PanicFalse(StreamConnect(left_port, lSink_A));
        PanicFalse(StreamConnect(right_port, lSink_B));
    /* mono operation, only connect left port */
修改目标:采样率-48k,双通道、16位, 位时钟:48k * 32
MCLK_SCALING_FACTOR 修改为256、128、64时,I2S还有数据输出,而设为32时,没有数据输出。有人知道什么问题吗?
签到总天数:885天
签到总奖励:15306金币
发表于 2014-6-19 09:56:36 | 显示全部楼层
签到总天数:243天
签到总奖励:1834金币
发表于 2014-6-19 13:17:33 | 显示全部楼层
sorry, missed up
签到总天数:35天
签到总奖励:435金币
发表于 2014-7-26 21:41:05 | 显示全部楼层
通常MCLK=128*LRCK以上,最常见的是256倍,但绝不能等于位时钟。其实MCLK并非I2S必须,而是有的DAC需要用其进入睡眠或静音模式
发表于 2014-7-29 17:01:11 | 显示全部楼层
顶顶更健康,呵呵,小弟纯属灌水赚金币。
GMT+8, 2025-6-25 15:33 , Processed in 0.205061 second(s), 20 queries , Gzip On, MemCached On.
