查看: 2686|回复: 0
[其他] wallys WiFi6 MiniPCIe Module// MT7915 MT7975 2T2R 2×2.4GHz 2x5GHz openwrt21.02
签到总奖励:18金币
发表于 2022-8-24 16:01:06 | 显示全部楼层 |阅读模式
MT7915/MT7975/IPQ6000/IPQ6018/IPQ6010/IPQ4019/IPQ4029/IPQ4018/IPQ4028/IPQ8072/IPQ8072A/IPQ8074/IPQ8074A/IQCN6024/QCN9074/QCN9072/QCN9024/IPQ5018/AR9223/QCA9880/QCA9882/AR9582/AR9531/AR9344 /AR9342/AX200NGW/QCA9531
https://www.wallystech.com/Network_Card/DR7915-wifi6-MT7915-MT7975-2T2R-support-OpenWRT-802.11AX-supporting-MiniPCIe-Module.html
MT7915+MT7975 Chipset
2.4GHz max 23dBm & 5GHz max 20dBm output power
IEEE 802.11ac / ax compliant & backward compatible with 802.11ax/ac/a/b/g/n
2×2 2.4G & 2×2 5G  MIMO Technology, up to 1.8Gbps Mini PCI Express edge connector
SupporttheFrequency2412MHz~2482MHz
SupporttheFrequency5180MHz~5825MHz
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Supports Spatial Multiplexing,Cyclic-Delay Diversity (CDD), Low-Density Parity Check  (LDPC) Codes,Maximal Ratio Combining (MRC), Space Time Block Code (STBC)
Supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards
CardsareindividuallycalibratedforQualityAssurance
    Product Description
    DR 7915 based on MT7915 + MT7975 Chipset is an enterprise wireless module integrated with 2x2 2.4G high power Radio module and 2x2 5G high power Radio module designed
    specifically to provide users with mobile access to high-bandwidth video streaming, voice, and data transmission for office and challenging RF environment infactories, warehousese stablishment.
    Specifications
    Symbol
    Parameter
    Chipset
    MT7915+MT7975
    Host Interface
    Mini PCI Express 2.1
    Antenna Connector
    2 x UF.L
    Frequency Range
    2.4GHz: 2.412GHz to 2.472GHz
    5GHz: 5.180GHz to 5.825GHz
    Operating Voltage
    3.3V DC
    Power Consumption
    TBD
    Modulation Techniques
    OFDM: BPSK, QPSK, DBPSK, DQPSK, 16-QAM, 64-QAM, 256-QAM
    Environmental Temperature
    Operating: -40°C to 70°C, Storage: -40°C to 90°C
    Environmental Humidity, non-condensing
    Operating: 5% to 95%, Storage: Max. 90%
    ROHS Compliance
    YES
    Dimensions (W×H×D)
    51mm × 30mm × 5.8mm
    Commercial processes and communications are all managed utilising wireless technologies, and the number of users, devices and apps are only going to increase.  Therefore, it is essential to have a robust, secure and high performing WiFi solution that is future-proofed, mobile, and scalable.  Not only is business WiFi vital for your workforce and organisation, it is now imperative for visitors to be able to access a secure guest wireless network.
    Wallys has been specializing in product design & manufacturing and delivering superior OEM/ODM services in wireless communications. Dedicated to innovative designs for wireless modules. Customization is also supported, We have 90% of the world market, We're a supplier to Facebook.
    EMAIL:sales@wallystech.com
GMT+8, 2026-11-3 07:25 , Processed in 0.020684 second(s), 10 queries , Gzip On, Redis On.
