查看: 1968|回复: 1
[Bluesuite/PSKey] Wallys/MIMO/Industrial-grade/902-928Mhz/Industrial-grade/902-928Mhz/AR9223/ A...
签到总天数:8天
签到总奖励:36金币
发表于 2022-10-19 13:58:14 | 显示全部楼层 |阅读模式
MIMO/Industrial-grade/902-928Mhz/Industrial-grade/902-928Mhz/AR9223/https://www.youtube.com/watch?v=5Iiq4PZxnBw]AR9582[/url]/AR9531/AR9344/ AX200NGW /AP9342
We have experienced R&D engineer team with a demonstrated history of working in the wireless industry.Skilled inRF and embedded communications,network protocol,firmware,openwrt,linux,system,development,analog and Digital Circuit Design,Network Processors,Power supplies,PCB design and layout and etc.,
Welcome to email us for any project or question about RF and embedded systems
Moreover, we can also do FCC and CE certification related to wireless communication products for you. There is a better price for certification in China.
BY:Wallys Communications (Suzhou ) Co., LTD
1. WFC900M
AR9582 2x 2 900M 802.11an
2x2 MIMO Industrial-grade 902-928Mhz
https://www.wallystech.com/Network_Card/WFC900M-Qualcomm-Atheros-AR9582-2T-2R-MIMO-802.11-N-900M-high-power-Mini-PCIe-Wi-Fi-Module.html
Featuring with industrial-gradeAtheros’s AR9582chipset
Integrated with 2x 2 900M high powerRadio Card
905MHz to 925MHz Frequency Range
2 x MMCX Connectors
5M/10M/20MHz Bandwidth
Support 11AN
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Absolute Maximum Rating
Parameter
Rating
Unit
Supply Voltage
3.3V(MINIPCIE)
V
Operating Temperature Range
-40 to +60
ºC
Storage Temperature Range
-65 to +105
ºC
Operating Humidity Range
5 to +95 (non-condensing)
Storage Humidity Range
0 to +90 (non-condensing)
Hardware Specifications
Symbol
Parameter
CPU
AR9582
Antenna Connector
2 x MMCX connectors
ROHS Compliance
YES
Dimension
79mm x 51mm x 10mm
802.11ac/802.11ax, panel antenna 2.4G 11dBi,
mmcx connector
https://www.wallystech.com/Antenna/DR2G11-Panel-Antenna-2.4GHz-11dbi-support-802.11ac-ax-mmcx-connector.html
1. Feature
* 11dBi Dual Polarized Micro strip  Antenna Array
* 2.4GHz of frequency
* MMCX connector
* Support 802. 11AX/AC/AN
* RoHS compliance
2. Application
* 2.4GHz Wireless Communication
签到总天数:124天
签到总奖励:2891金币
发表于 2023-7-7 15:08:00 | 显示全部楼层
完全看不懂…
GMT+8, 2025-6-16 13:19 , Processed in 0.120386 second(s), 13 queries , Gzip On, MemCached On.
