查看: 2416|回复: 0
[供应] Wallys|wifi6 Qualcomm IPQ8072A 4T4R support QCN9074/QCN6024 MOUDLE OPENWRT
签到总奖励:21金币
发表于 2023-1-3 15:11:35 | 显示全部楼层 |阅读模式
With a history of 10 years, Wallys has been very mature in the design and development of hardware and software in wireless communication. It also supports customization and software development, and has won the trust of 90% of customers around the world and reached a long-term cooperative relationship. It is also a supplier of facebook.
Wallys mainly uses Qualcomm and MTK chips. The main products include router, moudle, industrial access AP and antenna, which are of industrial grade, and the quality and performance fully meet the requirements of users.
The following are the best-selling products of Wallys. Let's take a look at them together. You can contact us at any time if you are in need, or enter our company's official Website to check more product information.
DR8072 V01
https://www.wallystech.com/Routerboard/DR8072V01-wifi6-Qualcomm-IPQ8072A-4T4R-support-OpenWRT-802.11AX-supporting-10GE-port-10G-SFP.html
Network SBC based on Qualcomm IPQ8072A communication processor with two 10GbE interfaces. One of these interfaces is implemented through an SFP rack and the other is based on an RJ45 connector. In addition, the SBC has four gigabit Ethernet ports that provide WiFi 6 connectivity (AX3700) at 4x4 MIMO.
SoC -- Qualcomm Atheros IPQ8072A quad-core Arm Cortex-A53@ 2.2GHz Qualcomm Networking Pro 1200 Platform
System Memory - 512MB DDR4 2400 MHZ 16-bit interface (up to 2GB RAM is optional)
Storage -- 8MB NOR flash, 256MB NAND flash
network
wireless
Onboard 4×4 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax with a maximum of 17dBm per chain and up to 1147Mbps
Onboard 4×4 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax with a maximum of 17dBm per chain and up to 2475Mbps
Frequency -- 2.412 to 2.472 GHz and 5.150 to 5.825 GHz
Modulation technology OFDMA, BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM
8x U.L antenna connector
The cable
1x 10Gbps Ethernet RJ45 port
1x 10Gbps SFP rack
4x Gigabit Ethernet RJ45 port
USB - Two USB 3.0 ports
Expansion - 1x MiniPCIe slot and PCIe 3.0
Debugging - 20 pin JTAG connector, 4 pin serial connector
Others -- 1x software reset button, 2x RGB LED
Power supply - Provides 12V power through a DC jack
The temperature ranges from -20oC to 70oC. Storage: -40oC to 90oC
Support WiFi 6E Card,802.11ax,QCN9074
IPQ8072 4x4 2.4G & 5G 802.11ax
Features
■ Qualcomm Atheros IPQ8072A AR Quad Core CPU
■ On-board 5GHz radio, up to 2475 Mbps physical data rate,On-board 2.4GHz radio, up to 1147Mbps physical data rate
■ 8 MB NOR Flash, 256MB NAND Flash(NAND Flash can be up to 1GB as optional)
■ Support 11ax TX Beamforming,Support 11ac/ax MU-MIMO DL and UL,Support OFDMA DL and UL
■ DDR 1GB DDR3L(Support DDR3L can be up to 2GB as optional)
■ M.2 connector can support QCN9074 production
DR9074-6E(PN02.7)
QCN9074 802.11ax 4x4 MU-MIMO 6GHz wifi6E
QCN9074 supports 4x4MIMO, and the maximum speed can reach 4804Mbps in theory when the bandwidth is set to 160MHz. If you use 2x2MMO, you can support 4096-QAM with a theoretical maximum rate of 2882Mbps.
QCN9074 11ax 4x4 6G M.2
Features
■ Qualcomm Atheros QCN9074
■ 6GHz, max 23dBm per chain, up to 4949Mbps
■ Single Band 6GHz 4x4 WiFi 6E (802.11ax)
■ 4 spatial streams (4SS)
■ M.2 E Key Interface
■ PCI Express 3.0 Interface
APPLICATIONS
Profi WiFi hotspot coverage
Commercial radio coverage
Hotel Wireless application
Country coverage
Internet for passengers (bus, train, plane, …)
Security Surveillance
Some special scene application
Heavy-duty industrial environment use
Stable networks guarantee for the ongoing continuity of your video surveillance. Our boards could establish a stable connected wireless environment which is critical for a security surveillance system.
Wallys has been specializing in product design & manufacturing and delivering superior OEM/ODM services in wireless communications. Dedicated to innovative designs for wireless modules. Customization is also supported, We have 90% of the world market, We're a supplier to Facebook.
We'll start with a quick review of how Wi-Fi has changed over the years.
In fact, the earliest generation of 802.11 standard can be traced back to 1997, when the wireless speed is very low, only 2Mbps, it is an original standard of the first generation .
With the introduction of 802.11b in 1999, the physical layer speed was increased to 11Mbps and there were very few commercial applications. At that time, Wi-Fi was still far away from people's lives
In 2003, the third generation of the standard, 802.11a/ g. Laptop began to configure wireless network card and home wireless router appeared in large quantity . Wi-fi comes into ordinary family.
Wallys are able to provide customizable solutions based on your your Spec requirements for applications, feel free to let me know if any question.
GMT+8, 2026-11-3 04:42 , Processed in 0.026111 second(s), 12 queries , Gzip On, Redis On.
