查看: 2657|回复: 0
[供应] Wallys//IPQ8072/IPQ8074/IPQ8072A/IPQ8074A/HighPower 802.11ax SoC for Routers...
签到总奖励:21金币
发表于 2023-1-3 15:24:29 | 显示全部楼层 |阅读模式
DR8074
https://www.wallystech.com/Routerboard/DR8074A-HK01-wifi6-Qualcomm-IPQ8074A-4T4R-2-4GHz-and-8T8R-5GHz-support-OpenWRT-802.11AX-MU-MIMO-OFDMA.html
IPQ8074 is Qualcomm's first WiFi6 networking solution designed to meet the growing demands of increasingly crowded and dense Wi-Fi environments. It offers the best configuration to bring unprecedented capacity and coverage to Wi-Fi networks and supports several unique features to ensure the best Wi-Fi performance for all types of applications. IPQ8074A compared with IPQ8074, IPQ8074A has added the MU-MIMO Uplink, OFDMA-UL, MU-RTS (Multi-User Request To Send), Preamble Finally, Spatial Reuse (OBSS PD). Maximizing the payload data rate by improving efficiency reduces contention between STAs and improves channel utilization. This shows that IPQ8074A can have more stable and higher wireless data rate, anti-interference ability is also more excellent.
DR8074A(HK01)Features
■ Qualcomm Atheros IPQ8074A AR Quad Core CPU
■ On-board 5GHz radio, up to 4804Mbps physical data rate 32MB NOR Flash, 256MB NAND Flash
■ On-board 2.4GHz radio, up to 1147Mbps physical data rate
■ Support 11ax TX Beamforming
■ Support 11ac/ax MU-MIMO DL and UL
■ Support OFDMA DL and UL
■ Tri-band support with 5G SBS (4x4/5GHz + 4x4/5GHz) + 4x4/2.4GHz
Hardware Specifications
Symbol
Parameter
CPU
Qualcomm Atheros Quad Core ARM Cortex 64-bit A53 Processor IPQ8074A 2.2GHz CPU
CPU Frequency
Derived from Qualcomm Atheros AP.HK01
System Memory
1GB (2x 512MB) DDR3L 32-bit interface
Frequency Range
2.412GHz to 2.472GHz, 5.150GHz to 5.825GHz
Modulation Techniques
OFDMA: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM
NGFF Slot for 5G Module
M.2 (NGFF) “B Key” Socket with PCIe 3.0 interface
Optional Onboard Modules
Supports 1x BT module,1x ZigBee module,1x Touch pad connector,1x Audio header,1x LCD display header
Flash
NOR Flash: 32MB NAND Flash: 256MBeMMC: 8GB
Wireless
On-board 4x4 2.4GHz MU-MIMO 802.11b/g/n/ax, max TBDdBm per chainOn-board 2x(4x4) or 8x8 5GHz MU-MIMO 802.11a/802.11n/802.11ac/802.11ax, max TBDdBm per chain12x U.FL connectors
Reset Buttons
2x Hardware reset button, 1x WPS reset button
DC Jack Input
1x DC Jack Connector: 12V, 5A
Interface
5x Gigabit Ethernet (1GbE) LAN/WAN RJ45 Port (Auto MDI-X)1x 10Gigabit Ethernet (10GbE) LAN/WAN RJ45 Port (Auto MDI-X) 1x SFP+ Port2x USB 3.0 Port1x Serial Port 12 Pin Connector 1x JTAG 20 Pin Connector1x micro SD Card Socket1x M.2 Slot
LED
13x LED indicators, 2 additional LED on Ethernet port
Power Consumption
TBD
Wallys Communications (Suzhou ) Co., LTD) is a professional supplier of wireless communication products and has a complete industrial chain in China.
Its main business is to design and manufacture the latest industrial wireless products, such as router boards, network interface cards, access points, etc., with a wide range of industrial applications.Our biggest advantage is our independent research and development ability.We can provide one-stop customized solutions according to customers' detailed requirements.
Recently, our company launched many new products, such as Antenna (DRA24126ESBE),DR6018-S,DR6018C V01,DR8072 V01,DR40X9,DR9074-6E,DR9074-5G and so on.
For more products please visit: https://www.wallystech.com/product.html
Follow us in the Youtube: https://www.youtube.com/channel/UClmu7LBz_OWxe2VckkQr3tw
GMT+8, 2026-11-3 04:43 , Processed in 0.021537 second(s), 10 queries , Gzip On, Redis On.
