查看: 198|回复: 0
[供应] DR8072 Router Board with IPQ8072: Unlock High-Speed 10Gbps Ethernet and Advanced
发表于 2025-2-25 11:08:59 | 显示全部楼层 |阅读模式
DR8072 Router Board with IPQ8072: Unlock High-Speed 10Gbps Ethernet and Advanced Wi-Fi 6 Features
The DR8072 Router Board is a high-performance networking solution designed for industrial applications and demanding wireless environments. Powered by the Qualcomm IPQ8072A quad-core processor, this router board supports advanced Wi-Fi 6 (802.11ax) technology, offering exceptional throughput, efficiency, and reliability for mission-critical applications. Whether you're building a high-speed network for an industrial facility, a data center, or a large-scale wireless deployment, the DR8072 provides the performance and flexibility needed for the most demanding use cases.
Key Features of the DR8072 Router Board with IPQ8072:1. Powerful Qualcomm IPQ8072A Quad-Core CPU
At the heart of the DR8072 lies the Qualcomm IPQ8072A processor, a robust quad-core CPU that ensures high processing power and seamless handling of intensive data traffic. This makes the DR8072 ideal for high-performance applications where speed and stability are paramount.
2. High-Speed 10Gbps Ethernet Ports
The DR8072 features 1x 10Gbps Ethernet port and 4x 1Gbps Ethernet ports, delivering lightning-fast network speeds for bandwidth-hungry applications. Whether you're managing high-volume data transfers or building a high-speed backbone for your infrastructure, the DR8072 guarantees exceptional performance with minimal latency.
3. 10Gbps SFP Support
The 10Gbps SFP (Small Form-Factor Pluggable) port further enhances the flexibility of the DR8072, enabling high-speed fiber connections that are perfect for long-distance networking and high-performance data transmission. With both copper and fiber options available, the DR8072 adapts to a variety of networking setups.
4. Advanced Wi-Fi 6 (802.11ax) Support
Supporting Wi-Fi 6 (802.11ax), the DR8072 Router Board delivers up to 4x faster speeds and improved network efficiency compared to previous generations of Wi-Fi technology. This is made possible by advanced features such as MU-MIMO (Multi-User, Multiple Input, Multiple Output), OFDMA (Orthogonal Frequency Division Multiple Access), and TX Beamforming, which maximize the available bandwidth and optimize the network for multiple connected devices.
5. Versatile USB 3.0 Ports and Serial Connections
The DR8072 is equipped with 2x USB 3.0 ports, which offer additional connectivity options for peripherals or storage devices, and 1x 4-pin Serial Port for further integration into your system. These flexible connectivity options make the DR8072 suitable for a wide range of custom networking solutions.
6. Optional Expanded Memory and Storage
The DR8072 comes with 1GB DDR3L RAM (upgradable to 2GB) and 8MB NOR Flash with an optional 1GB NAND Flash for extended storage capacity. This ensures smooth operation for complex applications and larger data sets.
7. OpenWRT Support
The DR8072 supports OpenWRT, an open-source Linux-based router firmware that allows for advanced customization and flexibility in configuring your network. Whether you're looking to implement specialized security protocols, advanced routing techniques, or custom firewall rules, OpenWRT provides the tools you need to optimize the DR8072 for your exact requirements.
8. Dynamic Frequency Selection (DFS)
To avoid interference and optimize network performance, the DR8072 supports DFS (Dynamic Frequency Selection), a feature that enables automatic switching to less congested frequencies in real-time. This is crucial for environments with high wireless traffic or crowded spectrum.
Applications of the DR8072 Router Board:
The DR8072 is ideal for a range of industrial and enterprise applications, including:
  • [color=var(--color-text)]Industrial IoT (IIoT): Supports fast, reliable communication in smart factories and industrial environments.
  • [color=var(--color-text)]High-Speed Data Centers: With its 10Gbps Ethernet and fiber connections, the DR8072 is well-suited for high-demand data center environments.
  • [color=var(--color-text)]PTP/PTMP Networks: Perfect for Point-to-Point and Point-to-Multipoint wireless networking, providing long-range, high-speed connectivity.
  • [color=var(--color-text)]Enterprise Networks: Great for large-scale corporate networks that require high-speed, reliable connectivity for thousands of devices.
  • [color=var(--color-text)]Wi-Fi 6 Deployment: Ideal for high-density areas like stadiums, airports, and campuses where many devices need simultaneous connectivity.
Conclusion:
The DR8072 Router Board with the Qualcomm IPQ8072A processor is an advanced networking solution built for high-speed, high-performance applications. Whether you're upgrading your existing network or deploying a new solution, the DR8072 provides cutting-edge Wi-Fi 6 technology, ultra-fast Ethernet speeds, and extensive customization capabilities. With features like 10Gbps Ethernet, 10Gbps SFP, and OpenWRT support, this router board is equipped to handle even the most demanding wireless networking environments.
For more information or to inquire about purchasing the DR8072 Router Board, feel free to contact our sales team at [color=var(--color-action)][backcolor=var(--artdeco-reset-link-background-color-transparent)]sales1@wallystech.com.
GMT+8, 2025-5-28 03:58 , Processed in 0.225308 second(s), 14 queries , Gzip On, MemCached On.
