In Monopoly GO, a full Optic Blast charge creates a decision that ordinary digging does not: should you use it now or reveal more tiles first. If you split your attention between Monopoly Go Stickers and Treasures events, this is one moment worth slowing down for. Cyclops' cross-shaped blast can clear several useful positions, but its value comes from the board you target, not simply from having the ability ready.
Treat a full charge as a decision point
During the Doomsday GO! season's Treasures events featuring this ability, digging collects Booster points toward a Treasure Booster charge. Once the bar fills, you activate the power manually. You can hold only one full charge, so keeping it ready has a cost: you cannot store a second full activation alongside it.
That does not mean you should fire immediately. A short delay can be worthwhile if another carefully chosen dig would clarify an object's outline. The distinction is between waiting for useful information and waiting for certainty. If you already have a promising cross, continuing to dig without reconsidering the charge can waste an opportunity to use it productively.
Choose useful intersections, not attractive centers
Optic Blast clears horizontal and vertical lines in a cross-shaped pattern. A central position may look efficient, yet symmetry tells you little about the remaining treasures. Compare possible intersections against unresolved tiles and the shapes you have partially uncovered.
Favor a crossing whose row and column both reach promising hidden spaces.
Use visible treasure edges to judge which neighboring tiles deserve attention.
Give less priority to lines that pass mostly through cleared spaces.
A useful comparison is a central cross through largely empty ground versus an off-center cross that intersects two partially exposed objects. The second option has a clearer purpose, even if its position looks less balanced. Treat those object outlines as clues rather than proof, and avoid assuming every adjacent tile contains another piece.
You also do not need to finish an object with every activation. Revealing several relevant spaces can make the next pickaxe choice clearer. Judge the blast by how much useful work it can do, not only by whether it completes a treasure immediately.
Spend pickaxes to answer specific questions
Individual digs remain useful because they can reveal information that makes the blast easier to aim. Before spending another pickaxe with a full charge waiting, identify what that dig would tell you. A tile near a visible edge offers a more specific question than an unrelated square elsewhere.
Check whether one additional reveal could change your preferred blast position.
Activate when the existing clues already support a worthwhile cross.
Stop waiting if further digs are not improving your targeting decision.
This approach avoids two extremes: releasing the ability without inspecting the board and preserving it until almost nothing remains uncertain. Neither timing rule fits every layout. The practical threshold is enough evidence to choose useful coverage, with a clear reason for any extra pickaxe spent beforehand.
Recheck the board after the blast
Do not queue your next several digs mentally before activating Optic Blast. Its effect can expose edges, remove unresolved spaces, and change which tile deserves attention next. Inspect the result first, then choose a fresh target from what remains hidden rather than following an outdated plan.
Before moving from Treasures to the Monopoly Go Racer Event, keep your resource decisions tied to each event's own rules. For your next Optic Blast, use a simple test: if another dig would meaningfully change your aim, investigate; if it would not, take the useful cross already available.
