A full Glory meter does not guarantee a useful Nightmare activation in Path of Exile 2. You still need Mana, Shades worth transforming, and enemies that remain available during the attack window. Before spending Path of Exile 2 Currency on equipment for this setup, check whether your dagger rotation supports those conditions. The supplied preview makes preparation the first practical concern.
Count Shade creations, not visible copies
The preview assigns Nightmare a 100 Glory requirement and awards 13 Glory for each Shade created. Eight creations therefore reach the threshold if every event grants the full amount. The ordinary limit of three Shades does not contradict that requirement: the resource comes from creation events, rather than the number of copies standing beside you.
Use the resource display to judge readiness instead of counting visible Shades. Where encounter rules permit preparation, manageable enemies offer an opportunity to accumulate Glory before approaching a tougher target. Watch how late that threshold arrives during clearing, too. Reaching 100 Glory as the final enemy dies leaves you without an immediate target for the transformation.
Reserve Mana before committing equipment
Nightmare's previewed requirements are a Dagger, character level 52, 51 Dexterity, and 51 Intelligence. Activation also costs 68 Mana. Meeting the equipment and attribute requirements gets the skill into consideration, but a rotation that leaves less than the activation cost available will interrupt your intended timing even with sufficient Glory.
Prioritize reliable Shade creation and enough available Mana before spending heavily on equipment intended to support Nightmare. Keep your own dagger attacks functional, since you can continue attacking during the transformation. This setup suits players willing to track a resource cycle alongside melee combat; players who dislike preparing an attack window should consider that extra management before committing resources.
Spend the duration where enemies stay reachable
Activating Nightmare creates another Shade and transforms existing Shades into autonomous demonic attackers. Their displayed duration is 20 seconds. For a group encounter, choose a moment when enemies are already within reach and combat is about to continue. Activating in an empty passage consumes time that the creatures could otherwise spend pursuing and attacking targets.
Boss timing requires a different check. Look for an attackable phase with enough time for the creatures to engage, and hold the skill when a known immunity or movement phase is approaching. A ready resource meter is permission to choose your moment. Spending it immediately can waste part of the duration if the boss becomes unreachable.
Use independent attacks to create room to react
Ordinary Shades imitate melee attacks performed from Stealth, while Nightmare's transformed creatures move and attack independently. That changes what you need to do during their active window. You can reposition while they continue fighting, then resume your own attacks when an opening appears. Against groups, direct your attention toward dangerous enemies that still require immediate handling.
The creatures are invulnerable during their duration, but that protection does not extend to your character. Keep responding to incoming attacks and encounter mechanics instead of treating the transformation as a defensive shield. Defensive equipment and passives still deserve investment, especially if maintaining your own damage would otherwise tempt you to remain in an unsafe position.
Before your next equipment purchase, identify the actual interruption: slow Glory preparation, insufficient Mana at activation, or a poorly chosen target window. Consider cheap Path of Exile 2 Orbs only after separating an equipment shortfall from a timing mistake. Check the skill description in your version against the previewed values, then adjust the part of the rotation that prevents a useful activation.
