查看: 10|回复: 0
[生活闲聊] Compare Cold Eye Maps in MapleStory Classic World with U4GM
发表于 8 小时前 | 显示全部楼层 |阅读模式
Reaching 50 Cold Eye kills does not finish the hunting stage of Cold Spring in MapleStory Classic World unless you also have 30 Cold Eye Tails. For players budgeting around MapleStory Global Mesos, that distinction matters because extra fighting means more time and recovery supplies. Characters level 40 and above can start with Sabitrama in Sleepywood, but the useful preparation is simple: accept the quest, clear inventory space, and track both objectives.
Choose a hunting route your character can sustain
Another Path has 23 listed Cold Eye spawn points, compared with 15 in Sanctuary Entrance II and 13 in Sanctuary Entrance I. That makes Another Path a sensible first stop, especially when your character can move between targets without long interruptions. The spawn count gives you a starting point, not a guaranteed completion time.
Judge the map by how much of your route involves actually fighting Cold Eyes. If reaching the next target takes longer than defeating it, try one of the other locations. A smaller listed population can still suit your character better when movement and combat fit together cleanly. Avoid staying on a map solely because its spawn count looks better.
Keep the tail requirement ahead of the return trip
Faces in the Dark requires 50 Cold Eye kills and 30 Cold Eye Tails as separate objectives. Pick up tails throughout the hunt rather than checking your inventory only after the kill counter finishes. Reaching 50 kills with fewer than 30 tails leaves you with more hunting, so the counter alone is a poor signal to leave.
Use recovery pauses to check your tail total and remaining inventory space. Once the kill requirement is complete, concentrate on collecting the missing tails. The Tunnel That Lost Light I is another option, but its mixed monster population requires more selective targeting. Fighting unrelated monsters spends time and potions without advancing either Cold Eye objective.
Finish the delivery before evaluating the payout
Return to Sabitrama only after both hunting requirements are complete. Faces in the Dark awards 8,280 EXP, 1,272 mesos, 15 White Potions, and 15 Blue Potions. Those supplies form part of the reward, but avoid treating them as a reason to ignore potion use during the hunt. Recovery items spent reaching the target still affect what you retain afterward.
Speak with Sabitrama again to accept A Patient Hunger before leaving Sleepywood. This stage sends you to Manji in Perion with a warning and requires no further hunting. Reporting to Manji adds 5,796 EXP and 890 mesos, bringing the two stages to 14,076 EXP and 2,162 mesos, plus the potions and a random Lesser Cape Scroll.
Decide where the scroll fits before using it
The scroll reward has four possible outcomes: Cape STR Scroll: Lesser, Cape DEX Scroll: Lesser, Cape INT Scroll: Lesser, and Cape LUK Scroll: Lesser. Each has a 25% chance. Treat a matching stat as a favorable result rather than a promised upgrade, particularly if the scroll is your main reason for completing the questline.
Check both the stat and the cape you intend to keep. Spending a suitable scroll on equipment you expect to replace soon commits the reward before your next equipment decision. Holding it preserves that choice. If the stat does not suit your character, check its Free Market value before deciding whether selling it serves your next purchase better.
Before leaving for Perion, confirm that A Patient Hunger is active; after collecting its reward, compare the scroll with your planned cape replacement. Keep the guaranteed 2,162 mesos separate from any unconfirmed sale value when planning MapleStory Classic World Mesos spending, and commit the scroll only when its stat and your equipment plans line up.
GMT+8, 2026-11-27 22:27 , Processed in 0.022962 second(s), 7 queries , Gzip On, Redis On.
