查看: 35891|回复: 0
[供应] 供应立体声蓝牙模块CSR8640
发表于 2014-9-9 08:56:22 | 显示全部楼层 |阅读模式
1. Introduction
Boomtech Semiconductors Co., Ltd the pioneer of the Bluetooth 4.0 class 2 modules
BT1207 which is a high performance, cost effective, low power and compact solution.
The Bluetooth class 2 module provides a complete 2.4GHz Bluetooth system
based on CSR BC8 chip which is a single-chip radio and baseband IC for Bluetooth
2.4GHz systems including basic rate, EDR to 3Mbps and Bluetooth low energy
2. Key Features
• Fully Qualified Single-chip Bluetooth® v4.0 System
• Bluetooth Class2 operation (up to 10 meters range).
•-92dBm (typical) π/4 DQPSK receiver sensitivity
and -82dBm (typical) 8DPSK receiver sensitivity
• CSR's latest CVC technology for narrowband and
wideband voice connections including wind noise reduction
•Wideband speech supported by HFP v1.6 profile and mSBC codec
•Voice recognition support for answering a call,enables true hands-free use
• Multipoint HFP connection to 2 phones for voice
• Multipoint A2DP connection enables a headset(A2DP) connection to 2 A2DP
source devices for music playback
• Audio interfaces: I²S and PCM
• aptX, SBC, MP3 and AAC decoder support
• Wired audio support (USB)
•USB 2.0 (full-speed) interface for audio and charger enumeration
• Support for smartphone/tablet applications
• 5-band fully configurable EQ
•Audio codec with 2 high-quality dedicated ADC
Supported sample rates of 8, 11.025, 16, 22.05, 32,44.1, 48 and 96kHz (DAC only)
•High-quality audio 95.6 dB SNR on DAC playback
■Bluetooth low energy
• Dual-mode Bluetooth low energy radio
• Support for Bluetooth basic rate / EDR and low energy connections
• 3 Bluetooth low energy connections at the same time as basic rate A2DP
• Slim module with 23mm x 12mm x 2.0mm
• RoHS Compliant
3. Applications
• Low-cost speakerphones and car-kits
• Automotive Hands-Free Kits
•Wired stereo headsets and headphones
• High Performance Telephony Headsets
• Portable stereo speakers
GMT+8, 2026-5-16 12:41 , Processed in 0.069910 second(s), 10 queries , Gzip On, MemCached On.
