查看: 35699|回复: 0
[供应] 供应骆达立体声蓝牙模块1510
发表于 2014-9-20 09:19:56 | 显示全部楼层 |阅读模式
1. GeneralDescription
BT1210 is anoptimized single-chip solution which integrates baseband and
radio for stereo headset and speaker applications. It complies with Bluetooth
system version 3.0 with EDR function. It contains a powerful 48MIPS
dual-MAC DSP coprocessor for enhanced audio applications. The built-in
noise reduction and echo cancellation functions enhance the voice quality.
The integrated audio codec supports stereo line-input with bypass mode and
stereo output. Advanced multipoint supports HFP connection to two
handsets for voice, or two A2DP sources for music play back. BT1210’s
advanced voice prompt function can be customized by customers for different
voice commands.
2. Features
• Compliant with Bluetooth 3.0 specification
• Support EDR function
• A2DP profile version 1.2 compliant
• HFP profile version 1.6 compliant
• HSP profile version 1.2 compliant
• AVRCP profile version 1.4 compliant
• Embedded 48MIPS dual-MAC DSP coprocessor
• Support for Stereo codec
• Multi-band configurable EQ\
• Support stereo FM Radio control
• Support I2S Digital audio output
• Multipoint for HFP and A2DP
• Integrated Li-ion battery charger supports 400mA fast charging and
over-discharging protection
• Integrated 1.8V Buck and 3V LDO regulator
• Slim module with 25.5mm x 13.5mm x 0.8mm
3. Block Diagram
5. Module Package Information
6. Module Package Information
7. Example Application Schematic\
GMT+8, 2026-10-22 21:44 , Processed in 0.069389 second(s), 9 queries , Gzip On, Redis On.
