查看: 14749|回复: 0
[供应] SP8666E+SP6519F低功耗AC/DC控制电路做33W快充,5V~20V多个输出电...
签到总奖励:97金币
发表于 2022-6-9 19:12:35 | 显示全部楼层 |阅读模式
SP8666E 内置多种保护,包括∶输入电压过低保护(Brown-out),输入电压过高保护(Line-ovp),输出电压过压保护(VO_OVP),输出二极管短路保护,逐周期过流保护(OCP),过载保护(OLP),VDD过压保护(OVP),VDD 欠压保护(UVLO),过温保护(OTP)等。
全电压范围内待机功耗低于75mW,内置650V高压功率管。SP8666E 采用 ESOP-6 封装。
[url=https://www.eechina.com/data/attachment/album/202206/09/185500weppper5b3dd8eoq.png][/url]
DC-DC大电流降压车充芯片:SP6816F,SP1701F,SP1081F,SP1082F,SP1088F,SP1220F,SP1225F,SP1221F,SP1231FL,SP1233FL,SP1236HF,SP1232F,SP1237F,SP1238F,SP1239EF,SP1289EF,SP1253HN,SP1250HN,SP1257HN,SP1229HN,SP1259HN。
AC-DC副边6级能效恒压系列:SP6660,SP6620HP,SP6650,SP6669P,SP6666,SP8666,SP6648HF,SP6638HF,SP6649HF,SP6639HF,SP6649DF。
AC-DC原边控制恒压/恒流系列:SP5710,SP5713,SP5715,SP5717,SP5718。
AC-DC原边控制6级能效恒压恒流:SP2689F,SP2689AFB,SP2639F,SP2638F,SP2637F,SP2607F,SP2637AF,SP2635F,SP2650,SP2659F,SP2657F,SP2658F,SP2655F,SP2670,SP2679F,SP2678F,SP2675F,SP2699P,SP2698F,SP2695F,SP2695AF,SP2698AF,SP2731F,SP2738DF,SP2738CF,SP2739AP,SP2739P。
AC-DC同步整流系列产品:SP6500,SP6501FL,SP6505FL,SP6502FL,SP6503FL,SP6551FL,SP6552FL,SP6553FL,SP6566AFB,SP6566AFC,SP6568AFB,SP6534F,SP6534FB,SP6534FC,SP6506FC,SP6507F,SP6508F,SP6550,SP6530,SP6510,SP6536F,SP6536FB,SP6536FC,SP6516,SP6538F,SP6538FB,SP6538FC,SP6539F,SP6519F,SP6514F,SP6514FB,SP6518F,SP6518FB。
DC-DC升压芯片:SP1682。
GMT+8, 2026-10-24 18:01 , Processed in 0.062625 second(s), 9 queries , Gzip On, Redis On.
