查看: 13262|回复: 10
[QCC5系列] QCC5171 分线板
签到总天数:941天
签到总奖励:16740金币
发表于 2022-6-22 20:58:01 | 显示全部楼层 |阅读模式
我为此类开发板设计了 QCC5171 (BTM571) 分线板。 它的制作方式是,前 2 个引脚是麦克风 3 和 4,因此在此类板上它们没有连接,因此仅使用引脚 3,4,...,27,28。 在下一个开发板上,可以使用麦克风。
有人可以看看这个板并说它是否有任何好处? BTM525/BTM551 的类似板工作正常,所以我想知道是否有人可以测试这个。
签到总天数:2419天
签到总奖励:64952金币
发表于 2022-6-22 21:08:20 | 显示全部楼层
I think you can describe your question by english, it will be better
签到总天数:941天
签到总奖励:16740金币
 楼主| 发表于 2022-6-22 21:31:58 | 显示全部楼层
The development board is shown on the first picture. KiCad project for QCC5171 module is attached, as well as QCC5151/25 one. Upper row of pins (pins 1 and 2 on J1 and J3 in KiCad) should be left unconnected if such development board is used.
I'm wondering if anyone can verify that such QCC5171 module will be working fine.
Main concern is BTM571 footprint, it is not available here
I tried creating one based on BTM5xx, which is fine for BTM525 and BTM551 at least.
Another concern is the antenna. I used one from here (PDF to SVG and then import SVG into KiCad). QCC5151/25 breakout board's antenna has different size compared to original module, but it still works.
Maybe there's better antenna which I could use (i.e. SWRA117D)?
签到总天数:2419天
签到总奖励:64952金币
发表于 2022-6-22 22:50:16 | 显示全部楼层
these antenna can also work,but performance needs tuning
签到总奖励:5金币
发表于 2022-6-23 02:25:50 | 显示全部楼层
感谢分享
签到总天数:941天
签到总奖励:16740金币
 楼主| 发表于 2022-6-23 02:38:55 | 显示全部楼层
Do I need some kind of special hardware or it may be done in software?
How much more performance is it possible to achieve?
连续签到天数:4天
签到总天数:2964天
签到总奖励:100728金币
发表于 2022-6-23 09:03:33 | 显示全部楼层
这个就看你核心板的线路是否与开发板的对不对了。对应该不会有问题啊。反正只是测试开发就板载天线可以了
其实最简单你就在买开发板那买核心板就行了
签到总天数:221天
签到总奖励:2792金币
发表于 2022-6-23 09:10:05 | 显示全部楼层
好资料
连续签到天数:6天
签到总天数:4026天
签到总奖励:142318金币
发表于 2022-6-23 09:39:30 | 显示全部楼层
大写的:
签到总天数:2419天
签到总奖励:64952金币
发表于 2022-6-23 11:40:55 | 显示全部楼层
I think this pcb is for test, your antenna can work, it is ok
GMT+8, 2026-11-8 18:10 , Processed in 0.031140 second(s), 19 queries , Gzip On, Redis On.
