查看: 32475|回复: 0
[供应] 供应蓝牙音箱一拖二模块,支持DSP
发表于 2014-9-10 09:09:03 | 显示全部楼层 |阅读模式
立体声,同时连接两个手机自动切换
立体声输出,支持line in 音量加减低功耗,,内置DSP,支持音乐与通话功能,内置天线,体积超小。
1. Introduction
Boomtech Semiconductors Co., Ltd the pioneer of the Bluetooth 4.0 modules
BT1212 which is a high performance, cost effective, low power and compact solution.
The Bluetooth module provides a complete 2.4GHz Bluetooth system
BlueCore® CSR8670™ BGA consumer audio platform for wired and wireless applications
integrates an ultralow-power DSP and application processor with embedded flash memory,
a high-performance stereo codec, a power management subsystem,
LED and LCD drivers and capacitive touch sensor inputs in a SoC IC.
The enhanced Kalimba DSP coprocessor with 80MIPS supports enhanced audio and
DSP applications.
2. Key Features
• Fully Qualified Single-chip Bluetooth® v4.0 System
• Receiver sensitivity: -90dBm (basic rate) and -92dBm(EDR)
• 10dBm RF transmit power with level control from on�6�2chip 6�6�2bit DAC
• Support for CSR's latest CVC technology for narrow-band and wideband voice
connections including wind noise reduction
• Stereo codec with 2 channels of ADC and up to 6 microphone inputs
(includes bias generators and digital microphone support)
• Multipoint HFP connection to 2 phones for voice
• Multipoint A2DP connection enables a headset(A2DP) connection to 2 A2DP
source devices for music playback
• Audio interfaces: I²S PCM and SPDIF
• aptX, SBC, MP3 and AAC decoder support
• Serial interfaces: UART, USB 2.0 full-speed, I²C
Supported sample rates of 8, 11.025, 16, 22.05, 32,44.1, 48 and 96kHz (DAC only)
■Bluetooth low energy
• Dual-mode Bluetooth low energy radio
• Support for Bluetooth basic rate / EDR and low energy connections
• 3 Bluetooth low energy connections at the same time as basic rate A2DP
• Slim module with 19mm x 12mm x 2.0mm
• RoHS Compliant
3. Applications
• Smart remote controllers
• Wired or wireless soundbars
• Wired or wireless speakers and headphones
• Wearable audio (on-the-go)
• Wearable audio with sensors (health and wellbeing applications)
GMT+8, 2026-10-23 21:38 , Processed in 0.027677 second(s), 10 queries , Gzip On, Redis On.
